Pin for ecu clutch position sensor
Old Jun 17, 2008 | 07:43 PM
04gsna's Avatar
hello I believe that PIN 43 is used for the clutch position sensor. I own a 3rd generation eclipse and run dual ecu's, one of which is a flashable evo8 ecu. Since I am automatic I am trying to simulate a clutch position sensor so I can use launch control with my high stall converter. the problem I have ran into is that I tried grounding that pin to see maybe if I could toggle a ground into it to activate my launch control and I received no success. Does anyone know what that reads? is it just a 12v power that is removed when clutch is activated or is 12v pushed into it when clutch is pressed. I was just scared to fry my ecu.
Old Jun 17, 2008 | 08:26 PM
3geclipse's Avatar
im wondering the samething as you.....i been searching here for hours and i figured out that in order for the launch control to work it needs the signal from the vehicle speed sensor!!!!.....so can we do this??
Old Jun 17, 2008 | 08:34 PM
04gsna's Avatar
I am working on it. tomorrow Im going to use my friends car to see if I can check the harness for power or not. I want 2 step soo badd
Old Jun 17, 2008 | 08:51 PM
3geclipse's Avatar
me too0o!!!! ...two step on auto with the evo ecu!!! ..........please let me know if you get it doned....post it on the dual ecu thread on club3g...im
3geclipse^ from club 3g
Old Jun 17, 2008 | 08:53 PM
04gsna's Avatar
I know you are im 04gsNA
Old Jun 17, 2008 | 09:40 PM
EVOllie's Avatar
Pin 43 is right
Old Jun 17, 2008 | 09:45 PM
EVOllie's Avatar
and far as how the pin works? u got me cause i was doing something simular. i wasnt getting a reading 12 or ground clutch in or out on that pin.
the clucth saftey switch is wierd too....its a constant ground pedal out....it kills the ground to one side when pressed in. Its usually the other way around.
Old Jun 17, 2008 | 09:54 PM
04gsna's Avatar
so the ground idea is right, when the clutch is pressed the PIN is then grounded?
Old Jun 17, 2008 | 10:00 PM
EVOllie's Avatar
like i said i had a test light on the pin and had someone pressing the clutch in and out with ignition on and i got nothing. i tried my tester grounded and hot.
you using rush?
Old Jun 17, 2008 | 10:03 PM
3geclipse's Avatar
i tried and ground the clutch pin and it didnt do noting,the stationary limiter was still on even if the clutch pin is connected or disconnected.....
Old Jun 17, 2008 | 10:07 PM
EVOllie's Avatar
oh ur using the stock stationary rev....i believe its speed sensor relalated. i know when my tires move at all it comes out of stationary rev..
Old Jun 17, 2008 | 10:10 PM
04gsna's Avatar
you using rush?
whats rush?
Old Jun 17, 2008 | 10:12 PM
3geclipse's Avatar
yea the stock one and your right i been reading in the forum and people mentioned the speed sensor...how could i trigguer the two step to turn it on and off then??
Old Jun 17, 2008 | 10:14 PM
3geclipse's Avatar
o maybe then since its speed sensor,we just have to put the value in and the when the car is running the stationary limiter should disable itself!!
Old Jun 17, 2008 | 10:16 PM
04gsna's Avatar
this is something I will try tomorrow
