Evoscan 2.3 released.
Old Jul 10, 2008 | 02:52 PM
  #136
Inprogress's Avatar
Originally Posted by Jack_of_Trades
its 850 I believe. With larger injectors, the lower the IPW is at idle with only the 33(ish) psi at full vacuum it may not be emitting a proper spray pattern to combust properly. I'm sure bumping the idle up 50-100 RPM would help if that is indeed the issue here.
Thanks Jack of Trades, I'll get with him and see what we can find.
By the way, my fuel trims moved on my car!!! I did a log at idle on evoscan and my LTFT lo were at -3.2, which is pretty solid right? I mean it's well within the 5% limit
Old Jul 10, 2008 | 02:55 PM
  #137
Jack_of_Trades's Avatar
Yeah, it will fluctuate no matter what you do so don't go crazy with it. There is a reason it has such a larger range because the ECU is supposed to correct for all the variances for you. Just get it in the ballpark and enjoy life
Old Jul 10, 2008 | 03:11 PM
  #138
Inprogress's Avatar
Yeah initially the trims started at -.6xx and then went to -1.82x for 4 minutes, then went to -3.2% and stayed for 4 minutes before I stopped logging, I was just extatic to see the trims friggin move lol
So even the LTFT move around that much? I thought only the STFT was there to add/subtract fuel at closed loop
Old Jul 10, 2008 | 03:27 PM
  #139
Through seasonal changes and barometric changes it will adjust a few percent I'm sure but it won't move much at all once it settles in.
Old Jul 12, 2008 | 06:46 AM
  #140
evo828's Avatar
I realised that the same data set is logging slower in 2.4 than it was in 2.1. Anyone observed the same behaviour? Logger superspeed turned ON on both versions.
v2.1 - cca 170 samples/sec
v2.4 - cca 120 samples/sec
Old Aug 20, 2008 | 12:21 PM
  #141
fahdc's Avatar
hi ,
anyone having a copy of evoscan and willing to share or any link where i can find a copy for free -
regards
Old Aug 20, 2008 | 12:25 PM
  #142
travman's Avatar
Its $25.00?
We all had to buy it - what makes you so special to get it for free?
Old Aug 20, 2008 | 12:41 PM
  #143
cossie1's Avatar
Originally Posted by fahdc
hi ,
regards
here you go.
www.imatightfistedgitandwanteverythingfornothing.c om
Old Aug 20, 2008 | 12:47 PM
  #144
Ph3n1x's Avatar
Still bumping this thread and 2.5 is out lol
Old Aug 20, 2008 | 12:52 PM
  #145
logic's Avatar
If you can't afford the $25 for EvoScan, may I suggest Mitsulogger?
Old Aug 20, 2008 | 12:53 PM
  #146
fostytou's Avatar
EvoM Community Team
Yup, just some asshat looking for a free lunch, and a free donkey ride, and a free flame bath.
Old Aug 20, 2008 | 04:31 PM
  #147
tephra's Avatar
the software: $25
the car: $25000
wanting it for free: priceless
Old Aug 20, 2008 | 04:55 PM
  #148
G20's Avatar
G20
hi ,
regards
You guys are too harsh. Visit here www.evoscan.org and get it for only $25. Common help the evo bro out will you. He spend many long hours developing it.
Old Aug 20, 2008 | 05:47 PM
  #149
logic's Avatar
I agree with G20, as far as the harsh comments go. He was looking to pirate EvoScan, but that might have simply been because he was unaware that there was a free alternative for those who don't need the bells and whistles EvoScan offers, especially after getting used to the idea of freely-available software with EcuFlash. Hence, my suggestion of Mitsulogger.
Now, if he knew there was a free alternative, and still wanted to pirate someone else's commercial product, then he's just a cheap freeloader. But hey, benefit of the doubt.
Old Aug 20, 2008 | 05:59 PM
  #150
tephra's Avatar
.... Its $25...
I mean come on - you spend more than that in fuel every week...
