Log help
Old Jun 25, 2008 | 08:39 AM
Nevonate's Avatar
Log help
Here is log that I took this morning on the way to work. I consolidated the log, to only show WOT. I also have a WB o2 and JDM Map (shown in log). I'm getting a little knock even though I am at 11:1 AF. Do you think I'm running t much boost. It's a 2004 evo8 with a 10.5 (2005 Evo8) hotside.
I converted the log to PDF for your viewing pleasure.
-Nate
File Type: pdf
Old Jun 25, 2008 | 08:46 AM
jmelocik's Avatar
Sorry what gear?
Josh
Old Jun 25, 2008 | 08:51 AM
TeStUdO's Avatar
Lower your timing 1* from 3k to 4k from 160 to 260 load and it should eliminate that knock. You never hit 3 counts, so it isn't too bad.
Old Jun 25, 2008 | 09:31 AM
Nevonate's Avatar
This was a third gear pull.
Testudo, do you think I'm running to much boost?
Old Jun 25, 2008 | 12:03 PM
TeStUdO's Avatar
Well, it's a tradeoff more boost/less timing or more timing/less boost. Every car responds different. With the way your boost tapers from 23 lbs to 17 by 7k, you should look into some other kind of boost control.
Old Jun 25, 2008 | 12:55 PM
Nevonate's Avatar
I'm using truboost. I have my Spring crack rate @ 5.7 but from what I'm reading that may be to high. I'm going to turn it down to 4 and see what that does.
redSLed
Jan 9, 2017 05:22 PM
ekizenbe
Sep 7, 2016 12:51 PM
Magnet
Apr 11, 2016 11:02 PM
05blue8
Apr 20, 2007 08:36 PM
KazzEvo8
Dec 3, 2005 11:15 AM
