Odd injectors ...
Old Jul 2, 2008 | 09:06 AM
TouringBubble's Avatar
Odd injectors ...
I've been working on scaling for a set of 950cc injectors ... they are acting a little funny ...
Scaling is set around 630cc I believe with the latency increased a little. This puts the low trim at about +6 and the mid trim around +2. Acceptable IMO for that size injector, but it seems very low for a 950. He even checked the part number to verify the injector size.
But the fuel map is very strange. It seems that the injectors spray a ton more as load/RPM rises. For instance, 12.2 might give me 11.5 @ 4000 and 180, but it takes 13.2 to get the same 11.5 @ 4000 and 220. The same goes for increasing revs at the same load.
So, the act like 780's at idle/cruise, but like 950's in boost.
Is this common, or is it maybe a fuel pressure issue?
Old Jul 2, 2008 | 01:39 PM
logic's Avatar
630 scaling is abysmally low for 950s. Something is definitely not right.
Have these injectors been spray/flow tested, by any chance? Can you log (or observe) fuel pressure on this car, preferably post-filter? Low-hanging fruit: have you tried changing the fuel filter?
Just a couple of ideas off the top of my head.
Old Jul 2, 2008 | 01:52 PM
The car is 2 states away ... I'll see if he's checked the filter though.
Old Jul 2, 2008 | 02:12 PM
logic's Avatar
Wait, they behave normally under boost, ridiculous at idle/cruise? Vacuum leak, maybe? Problem with the intake snorkel? Venting? Now I'm thinking an air metering problem; does airflow at idle look normal?
It's a couple more ideas, anyway.
Old Jul 2, 2008 | 03:52 PM
RazorLab's Avatar
Which injector brand?
If you are getting +6 FT at idle it needs more latency. It also needs more scaling if you are both +6 and +2 at mid.
Are they Low Impedance?
Old Jul 2, 2008 | 04:23 PM
dan l's Avatar
What fuel pump?
Old Jul 2, 2008 | 05:30 PM
oldevodude's Avatar
What i found with my limited experience scaling injectors is the global value is relative to the actual latency values. You could get trims to plus or minus 2 with a lower global right now but the ratio of mid to low trims being off means that you need way more latency to get a higher global more in line with your injector size. as you raise the global the ratio of low to mid changes when it fuels the car. If your 950's have a global of high 7 or low 8 hundred range with the right latency values then your fueli map will more accurate IMO .
Hopefully this makes sense.
Good Luck
Fast_Freddie
Oct 30, 2023 01:56 AM
bholland
Oct 9, 2014 10:47 PM
ApacheToYaDome
Jun 6, 2013 04:48 AM
LIL EVOL
Nov 29, 2007 03:51 PM
evopower1021
Jun 13, 2007 09:58 AM
