Turning off knock sensor under certain conditions?
Old Jul 22, 2008 | 09:37 AM
Lucas English's Avatar
Originally Posted by dudical26
Is there a way to make it so that you can log to see if there is knock while also preventing the ECU from recognizing knock.
Sort of turning the knock sensor off but only for timing purposes and leaving it on from logging purposes.
This would be the best way, you could then read the plugs and see whats happening to an extent to see if its real or phantom.
Old Jul 22, 2008 | 09:54 AM
l2r99gst's Avatar
It would definitely be worthwhile to have this mod, especially with high mileage, noisier lifters, aftermarket cams, springs, etc, that may throw things off a bit.
DSMLink had this ability and I had noisy lifters in my DSM (over 100,000 miles). I made sure it was phantom knock first, but once determined, I simply disabled the knock sensor in low RPM/load ranges. The car drove 100% better during daily driving.
Since most cars with phantom knock issues seems to have them at low load areas, I think a patch like this would be a great addition. Of course, before using this new feature, you should be absolutely sure that it is phantom knock first, either by checking the plugs as Lucas mentioned, or via timing adjustments, higher octane gas, etc, etc.
Eric
Old Jul 22, 2008 | 10:43 AM
justboosted02's Avatar
what about a user definable rpm dependent scaling factor for the knock sum, you could essentially tune the knock sum this way.
example,
if between 1000-2500 rpm the ecu sees say 14 counts, have a table where you could apply a scaling factor of say 0.5 and export that value (knock count of 7) to what the ecu sees for timing reduction purposes.
maybe this could be incorporated into a patch
just a thought
Old Jul 22, 2008 | 10:55 AM
joedr's Avatar
EvoM Moderator
Good thought on that one!
I can see a lot of advantages by doing that on the stock ECU.
Old Jul 22, 2008 | 11:46 AM
ecuflasher's Avatar
Originally Posted by tephra
yeah well thats the other thing - is 2500rpm/70-100load actually phantom knock or is it real?
Well...let me see....I have tried reducing timing and running richer, increasing timing and running richer, reducing timing and running C16, increasing timing and running C16, changing to a new knock sensor, installing a new set of hydraulic lifters, tightening everything in the engine bay down, and buying an aftermarket knock sensing kit and driving around with headphones on my head. I have one more thing left to try and that is to change out the twin metal clutch
Looking at my logs...most of the time, it just throws ridiculously high number of knocks, retards timing but the OCT number remains at 255. At this point in time, I just want to turn the damn sensor off during low load. I will take the 0.01% chance that it isn't phantom knock
Old Jul 22, 2008 | 11:56 AM
evo828's Avatar
Originally Posted by KOTT
how to turn it off completely?
last bit in ecu perephery 0 - if changed to 0 it turns the whole knock control off - at least this is what I ve understood on the aktivematrix.com discussions - but I am too scared to try it
For 96530006 - perephery 0: stock value is 56da - if you change it to 565a - knock sensor is disabled.
definition of those value in Ecuflash for 96530006:
<table name="ECU_PEREPHERY0" category="Misc" address="faa" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY1" category="Misc" address="fba" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY2" category="Misc" address="fca" type="1D" level="4" scaling="Hex16"/>
<table name="ECU_PEREPHERY3" category="Misc" address="fda" type="1D" level="4" scaling="Hex16"/>
Old Aug 13, 2008 | 02:27 AM
supersal's Avatar
Hi ecuflasher,
Did you make any progress with reducing your phantom Knock on the stock ECU...
Figure out how those knock filters work yet?
Thanks
Sal
Old Aug 13, 2008 | 03:33 AM
ecuflasher's Avatar
I was going to turn off the knock sensor completely when I made an interesting observation. My knock counts dropped by a fair amount after I flashed in the same map with absolutely nothing changed in order to reset the fuel trims. Now I'm wondering if its the ECU that's acting up after being flashed so many times...I probably have around 300 flashes on mine currently
Are you having problem with part throttle low load knocks too?
Old Aug 13, 2008 | 11:42 AM
JohnBradley's Avatar
I have over 3000 flashes on my stock computer and dont have random issues yet. It might be something else that was causing the problem. There were no changes at all though in the tune?
Old Aug 13, 2008 | 11:53 AM
Mellon Racing's Avatar
sometimes a flash will go awry during the process and simply reflashing will clear it up. I've had customers turn the key off during etc...pretty scary but I've never had one not recover.
Old Aug 13, 2008 | 04:49 PM
dan l's Avatar
In my DSM, I've disabled knock timing pull below what an Evo will represent as 100% load. You will NOT hurt a 4g63 doing this due to knock.
It would be nice to dial in a certain amount of timing pull per knock at the higher loads. Like 1 degree per count, or 1/7 degree per count. Or if you want to turn it off, 0 degrees per count.
The ideal situation would be to make your own knock filter map, but it seems this is much to complicated for the time being.
Old Aug 13, 2008 | 06:28 PM
ecuflasher's Avatar
Absolutely no changes in the ROM. I also noticed the radiator fan and cabin light acting strangely sometimes by cycling on and off once or twice with the car turned off and the key in my pocket Maybe its other issues than the stock ECU but I am not sure.
Old Aug 14, 2008 | 02:56 AM
supersal's Avatar
I am still running in my motor but I have noticed with the run in map that it picks up some knock on 1 or 2 part throttle pulls...
Not sure if its going to be a problem, but I am aware that Forged motors seem to pick up a lot of Phantom knock and this will mess around with the timing... limiting the true potential of the motor.
Just thought that I should be prepared if it does become a problem when I'm tunning...
Old Aug 14, 2008 | 05:04 AM
travman's Avatar
I agree......I am sick of my car pulling timing for random 1-3 counts of knock. I have tuned a few VIII's and they are much less sensitive some i have seen not pull any timing until like 5 counts. I don't know why the IX's (least mine) pull 1 degree per count of knock - its really quite ridiculous..
Would be nice to be able to set that up to pull X amount of timing per X amount of knock as danl stated.
Old Sep 2, 2008 | 12:51 PM
travman's Avatar
bumping this thread to see if anyone has been looking into anything with this topic and suggestions.
i wish i could help but im just a construction manager - what do i know?
