have problem with knock retard
Old Jul 16, 2008 | 01:45 PM
Mellon Racing's Avatar
without knowing the boost I'd agree, it's likely too much timing for the mods/boost/octane.
Old Jul 16, 2008 | 02:08 PM
KOTT's Avatar
much timing? for 0.8 bar and 10.8 afr???
try less ign, doesnt help...doing less for 1,2,3...5..7 degrees.... doesnt help
BUT if i going huge ign (~20 to redline) car stil reduce ign, bit it's goes great and when it retard ign it slows....
Old Jul 16, 2008 | 02:54 PM
evo828's Avatar
I do not think the timing is too high. My edm evo VIII - less mods than you have - runs 15deg at 1.3bar at 6000rpm with 11.3 afr - on regular 98okt (european RON). Although now I have to admit that during these high temperatures (around 30 deg C) - I get some knock occasionally. So now I am decreasing timing for this "summer" map.
Do you have a log with MAP and measured wideband visible through some range of RPM? Is it just getting knock above 6000rpm?
Old Jul 16, 2008 | 09:35 PM
RazorLab's Avatar
11psi and 249 2byte load at 6,000 rpm (according to that log you posted) doesn't add up.
Old Jul 17, 2008 | 01:37 AM
evo828's Avatar
Seems weird to me as well - that is why I asked for the MAP and AFR values - as part of the log - as I am not sure how these have been measured - and how they behave during the pull.
Old Jul 17, 2008 | 02:09 AM
burgers22's Avatar
Your running a loads more timing than I am even in the lower cells, and your log shows 10 deg advance at 6K with a 250 load. You might have another problem but try a more convervstive map to start with.
MB
Old Jul 17, 2008 | 05:26 AM
KOTT's Avatar
ty, will try
i cant post log with AFR, because ecuedit doesnt suport AEM w/b
Old Jul 17, 2008 | 06:08 AM
can you get evoscan or mitsulogger so we can help?
Old Jul 17, 2008 | 09:17 AM
mplspilot's Avatar
ty, will try
Слушай, мужчина. Скачай Evoscan и мы тебе поможем. Твой Ecuedit бесполезная вещь. AFR нет, лог короткий и не читаемый... Get with the program.
Old Jul 17, 2008 | 02:02 PM
I don't know what the hell you just said but I think I like it
Old Jul 18, 2008 | 04:03 AM
KOTT's Avatar
ок, я понел)
на зло еще карта просрочилась((
ok i will try to get evoscan
Old Jul 18, 2008 | 10:51 AM
mplspilot's Avatar
I basically said Ecuedit - Niet.
Evoscan - Da.
Nazdorovie!!
