EGR removal and CEL
Old Jul 15, 2008 | 04:06 PM
EvoIXMR's Avatar
EGR removal and CEL
Now, I understand that there is a fix for elimination of EGR and the CEL, but does this actually allow removal of evap can etc from the rear as well?
Basically, there is an evap emission ventilation solenoid as well and wondering if unplugging it causes a CEL...
Thanks!
Old Jul 15, 2008 | 04:56 PM
EvoDan2004's Avatar
the egr fix works great. i het no cel's with it. and yet it can be removed but make sure you put a plate on the manifold.....
as for the evap. nooooooo clue.
Old Jul 16, 2008 | 04:40 AM
dudical26's Avatar
removing the evap can will cause a cel and there is no fix yet as far as I know.
Old Jul 16, 2008 | 05:57 AM
MR Turco's Avatar
The egr fix with eliminate the CEL but i dont believe you can pass emissions test with it.
Old Jul 16, 2008 | 11:39 AM
EvoIXMR's Avatar
thanks, dudi.
I guess I wont touch it - you know me and weight reduction, Iwant it gone
Old Jul 16, 2008 | 11:40 AM
EvoIXMR's Avatar
Are you saying EGR fix will eliminate CEL for removing evap canister...
I am in Iowa - no emissions testing here whatsoever!
Old Jul 16, 2008 | 11:44 AM
dudical26's Avatar
I have to check my car, but he may be correct in saying that the EGR cell fix will also fix the cel for the EVAP canister.
It might just disable that whole slew of EGR/EVAP emission related checks.
But yea its nearly 10lbs so you need get that thing off the car. Another downside is that when the car sits you can sometimes smell gasoline fumes, and when you fill up it really stinks.
Old Jul 16, 2008 | 12:06 PM
EvoIXMR's Avatar
Dudi - Sending you a PM regarding removal of evap, you research it at all? The rear is confusing as hell. I am not sure what to remove and what not...there are lines galore!
Old Jul 16, 2008 | 02:13 PM
Lucas English's Avatar
There is control of all the EGR/Evap CEL with periphery 2 as MRfred posted with his explanation of it earlier.
Just a matter of taking the time to do all the binary math and then converting it to Hex.
Old Jul 17, 2008 | 04:08 PM
dxbtune's Avatar
From: I'm Canadian living and working in Dubai/Kuwait/Bahrain
I'm currently installing the AMS VSR intake manifold...
Im concerned with the cel light comming up with the missing sensors.
Has anyone come up with a solution in ecuflash?
appreciate any input fella's
Old Jul 17, 2008 | 04:48 PM
JohnBradley's Avatar
Yes we have.
Old Jul 17, 2008 | 05:13 PM
dxbtune's Avatar
^ excellent that's great news...
Can someone point me in the right direction as to how to get instructions on it or perhaps info i can share with my tuner?
Old Jul 17, 2008 | 05:28 PM
Smogrunner's Avatar
Originally Posted by JohnBradley
Yes we have.
I guess I'm p'owned again by not researching. I have this issue. Could someone explain how or post a link to a thread? I have had the CEL since getting my AMS VSR.
Old Jul 17, 2008 | 05:30 PM
EvoDan2004's Avatar
if you want. send me your rom and ill mod it for you so you dont get the light.
Old Jul 17, 2008 | 05:36 PM
Smogrunner's Avatar
Emailing you now. Thanks!
