HowTo: Identify Diagnostic Cables by PinOuts.
Old Jul 22, 2008 | 06:51 AM
evo4mad's Avatar
Mitsubishi 1994-2006 Vehicles:
MUT is 16pin OBDII plug with pins 1/4/5/7/16
1998+ OBDII is 16pin OBDII plug with pins 4/5/7/16
2001+ MUT Reflashing has an additional 12pin plug with pin 12.
Mitsubishi 1989-1994 Vehicles:
MUT is 12pin plug with pins 5/6/8
Hybrid 95-99 DSM/3000GT/Eclipse (16Pin)
Subaru SSM-I 1989-1998 Vehicles:
SSMI is 9pin plug with pins 2/3/5/9
SSMI is 16pin obdii style plug with pins 4/5/12/13
Subaru SSM-II 1998-2006 Vehicles:
SSMII is 16pin OBDII plug with pins 4/5/7/16
Old Jul 22, 2008 | 07:53 AM
evo828's Avatar
Hamish - modifying the MUT plug on a cable supplied by you (with pins 1/4/5/7/16 ) - will allow me to log the AYC/ABS items? If yes - can you please post how?
Old Jul 22, 2008 | 11:41 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
if i understand it right you just change the ECU in EvoScan to corresponding one AYC/ABS
Old Jul 22, 2008 | 11:52 AM
evo828's Avatar
no - doesnot work like that - I have tried already
nie - nefunguje to tak - ale na maile mi neodpoveda a dalsi kabel uz od neho kupovat nechcem
Old Jul 22, 2008 | 06:26 PM
evo4mad's Avatar
then you have an older cable where pin1 is connected to pin4 on the usb cable side. you need to change the car end to put wire from pin1(car obdii plug) to location pin15(car obdii plug)
this is the first time I have mentioned this, so a large number of people may pick up this information and actually start connecting to AYC and ABS now.
Old Jul 23, 2008 | 01:23 AM
evo828's Avatar
Hamish - thanks - I will try that.
If you do not want this info to get public - you should only send info to your "registered" customers
Old Jul 23, 2008 | 02:01 AM
jcsbanks's Avatar
So pins 1, 4 & 15 are all joined? Does this only work on Evoscan cables?
Old Jul 23, 2008 | 02:48 AM
evo828's Avatar
I do not think they are connected - because then it would work for my current setup.
Cable (evoscan cable) side OBD connectro has pins 1,4,5,7,15,16
Car side plug - has cables going into: 1,4,5,7,9,14,16
If moving car side pin 1 to pin 15 should solve it - then it leads me to a conclusion that they are currently NOT connected inside the cable plug. Will try it today evening.
Old Jul 23, 2008 | 02:58 AM
jcsbanks's Avatar
Looking at my Tactrix cable I have 4,5,7,9,11,15,16.
So could I join pin 4 & 15 to make this cable work for ABS/AYC?
Old Jul 23, 2008 | 03:16 AM
evo828's Avatar
based on what I understand what Hamish is proposing - you need to get the pin 15 on the cable plug to connect to pin 1 on the car side. So connecting 4 and 15 on the cable side will not help.
try to move pin1 into pin15 on the car side (female) connector.
Old Jul 23, 2008 | 03:51 AM
jcsbanks's Avatar
On the Tactrix cable 4 & 5 are ground, 7 is the K line, 9 & 15 are the L line, 16 is 12V.
In the service manual pin 1 & 7 are the diagnostic lines connected to the AYC/ABS/ACD.
So I can see why we connect pin 15 (L-line in Tactrix cable) to pin 1 on the car side. The next question is whether this will work on a Tactrix cable or just the Evoscan cable. Depends whether the L line is driven the same?
Old Jul 23, 2008 | 04:31 AM
jcsbanks's Avatar
I connected pin 1 and 9 on the car OBD plug with a patch wire (1 and 9 are next to each other). This effectively connects the Tactrix L line to the AYC/ABS/ACD diagnostic line.
With the ignition on the ACD and ABS lights were flashing. For the ACD all three lights were flashing if a cable was connected, and just the Tarmac light flashing more quickly if a cable was not connected.
I then used Evoscan 2.4 to try to connect. It managed to connect to the AYC ECU and return an ECU code, but didn't successfully log anything other than 255 on all requests with the engine off. However, the three ACD lights stopped flashing so I know it was connected. The actuators and DTCs didn't make sense/work.
For the ABS ECU, it kept cycling through the init procedure but returned an ECU code.
I've not tried with the engine on as a load of bulls have escaped from the field next to my house
Has anyone got Evoscan ACD/AYC/ABS logging working on an Evo 7-9 using any of the available cables or is it still to be debugged?
Old Jul 23, 2008 | 07:30 AM
jcsbanks's Avatar
I disconnected the wire from car OBD pin 9 and again connected pin 1 to the Tactrix L line. ABS still doesn't connect. AYC does, but Evoscan's request ID for TPS is not correct for my JDM IX. However, when I manually log request ID 1c I get TPS from the AYC computer. So the Tactrix cable can connect to AYC...
Old Jul 23, 2008 | 08:27 AM
jcsbanks's Avatar
Pin 9 is for ETACs. I'll reconnect and see if AYC logging will still work.
Old Jul 23, 2008 | 09:22 AM
jcsbanks's Avatar
"Logging" still works on the Evo 9 with pin 9 connected, but the data is nonsense and when you try to drive the ACD/AYC/ABS are doing weird things and it feels like something will break in the drivetrain just moving around at parking speeds. I think the logging items must be setting off actuators.
So has anyone got Evoscan working on an Evo 7-9 for the AYC/ACD/ABS with any cable?
