Quick Noob Question on Tephra.
Old Jul 24, 2008 | 08:45 PM
Turbo Kyle's Avatar
From what I understand when running the Tephra Patch the car only runs on ONE map (alternate Hi Octane Fuel/Ingnition map) the only way the car will run on the Alternate Low Octane Fuel/Ignition is if you have some sort of switch to go from the Hi map to the Low map...is this correct? Im going to start doing some slight modding to the timming/fuel....I just dont want to be chasing my tail.
Thanks,
Kyle~
Old Jul 24, 2008 | 11:13 PM
Turbo Kyle's Avatar
Bump
Old Jul 24, 2008 | 11:20 PM
tephra's Avatar
yeah.
So IX's usually have 3 hi oct timing maps.
V5+ removes #2 and #3 and just uses #1.
V5+ also adds an "alternate high oct timing map" which is used when on altmaps...
Make sense?
Old Jul 24, 2008 | 11:58 PM
Turbo Kyle's Avatar
Edit
Old Jul 25, 2008 | 12:02 AM
tephra's Avatar
No High/Low octane maps behave like normal
"Alternate" in the front means the set of alternate maps.
Just like you would tune low and high octane NORMALLY, you need to tune high and low octane when on altmaps.
Old Jul 25, 2008 | 12:04 AM
tephra's Avatar
Old Jul 25, 2008 | 12:24 AM
Turbo Kyle's Avatar
Old Jul 25, 2008 | 02:44 PM
Turbo Kyle's Avatar
Bump
Old Jul 25, 2008 | 02:46 PM
[EVO]Cookie's Avatar
Originally Posted by Turbo Kyle
Yes
Old Jul 25, 2008 | 02:48 PM
Use the alt maps for your E85 tune.
Old Jul 25, 2008 | 02:54 PM
Turbo Kyle's Avatar
Ok cool...I was looking at my first tune I pulled off the ECU. From what I read you want to make sure the Hi and low maps are the same...that way you allways know your running the same tune.
Then when you edit the tune make sure you adjust both maps.
Old Jul 25, 2008 | 03:00 PM
Yes and the alt maps can be flash switched for a track only tune or a alt fuel.
Old Jul 25, 2008 | 03:05 PM
Turbo Kyle's Avatar
Cool, Im running over to my buddys to get the WB working with EvoScan...and then we are going to to some slight tunning . I really want to get Innovates Log Works working with Evo Scan...it should make this more easy.
