First Log (2 byte) take a look
Old Jul 29, 2008 | 07:13 PM
Turbo Kyle's Avatar
UPDATE: My snorkle was not clipped down, I guess it wa getting sucked to the hood and cutting off air flow. Im got it fixed. I will be out for some loggs tomorrow....anyway this is why my load was going up and down.
This is a little chopped up Knock is on the left. I really need to get my keyspan adapter so I can long the innovate WB. Spiking at 24-25 psi. Mods are in sig. Here is my tune. All thoughts and flames welcome!
Knock left, timing on the right
and the rest
Old Jul 29, 2008 | 07:33 PM
Turbo Kyle's Avatar
Plotted the loads here...this is weird...or is it....Load goes up then down then up
Old Jul 29, 2008 | 07:46 PM
Turbo Kyle's Avatar
edit
Old Jul 29, 2008 | 08:53 PM
RazorLab's Avatar
mivec maxes at 28.8 so those 30's aren't doing anything.
You either have a boost leak or you are getting creep by looking at that load curve.
Old Jul 29, 2008 | 08:56 PM
Turbo Kyle's Avatar
Im thinking leak...cause I installed a LICP and didnt test it for leaks... Car is dropping to like 17-18 psi @ 7K
Got a nice MIVEC map you can Email me? This is one I got from a tunner over a year ago
Old Jul 29, 2008 | 09:04 PM
RazorLab's Avatar
18psi or so at 7k isn't too odd for a MBC. Although 245 load at 7k suggests you are holding a bit more.
Don't trust a boost gauge.
290 load at 5500 k looks like boost creep to me. What wastegate actuator are you using?
Old Jul 29, 2008 | 09:06 PM
fryedchikin's Avatar
There are a couple of great MIVEC maps to get you started in NJ's "How To Tune an Evo" thread.
Old Jul 29, 2008 | 09:16 PM
Turbo Kyle's Avatar
Stock...I do have the Evo Power Mods O2 dump...So I think it would keep me from getting creep. I did notice the guage held 25 psi for a decen amount of time...
Old Jul 29, 2008 | 09:17 PM
Turbo Kyle's Avatar
Thanks Razor is a Wizard...I was trying to ****** one from him
Old Jul 29, 2008 | 11:55 PM
Turbo Kyle's Avatar
Bump for the late night Owls
Old Jul 30, 2008 | 12:10 AM
Chamama's Avatar
The load does not seem to match with the timing up top. Its showing 16-17* timing at 7k but load is ~240. I am confused.
Old Jul 30, 2008 | 12:33 AM
Turbo Kyle's Avatar
Well the timming in the map is not the actual number (I think). If the map says 12 it doesnt mean the ignition timming is 12deg. The 12 is just a value thats coverted...so 12 should be 17 deg.
12* (x) = 17
Do the math and you should get the conversion number, x =1.416
12* 1.416=17
I think this is right but I cant be for sure.
Old Jul 30, 2008 | 10:48 AM
RazorLab's Avatar
Ah, I didn't even look at the logged timing.
Yes your 2byte load is incorrect. The ignition timing on the map is the timing the car is running.
Might be time to do some Maf scaling...
Looks like 200 load at 5500, not 290.
Old Jul 30, 2008 | 12:00 PM
Turbo Kyle's Avatar
So I need to fix my mods in the MUT table?
Old Jul 30, 2008 | 12:17 PM
RazorLab's Avatar
Which Rom # and what did you use for 2byte load
