Is my 2byte load logging correctly?
Old Jul 31, 2008 | 09:46 PM
MikeMAN's Avatar
I was FINALLY able to pull some useful data from EvoScan 2.5 Cant wait to start tuning!!! Do my values look fine after the 2byte load mod? The post i looked at didnt mention anything about modifying/adding the MUT table....yet i see lots of people talking about it for 2byte stuff? Or does this only apply to logging additional things such as 2byte airflow, rpm etc?
Old Jul 31, 2008 | 09:55 PM
G20's Avatar
G20
look good to me. the a/f is on the rich side from 4500-6000 rpm (I can't see them very well. It's too blur). Knock is very minimal. Did your car tuned?
What happened to the timing log?
Old Aug 1, 2008 | 04:38 AM
MikeMAN's Avatar
timing was logged...just figured i didnt need to post ALL the maps if they looked correct
Old Aug 1, 2008 | 07:14 AM
MikeMAN's Avatar
and the blurriness is because i tried to save them in lower quality before i realized, i had my own FTP/Web Server.
Old Aug 1, 2008 | 08:00 AM
laakness's Avatar
Not quite sure why you're hitting 11k RPM's when using 2byte RPM. In order to log 2byte correctly you are supposed to modify your 3D MUT table. Though the IX may have some of that enabled already.
Check for Jack_of_Trade's 2-byte thread. He's got all of the ECU ID's and MUT values for 2-byte rpm/load/air flow
Old Aug 1, 2008 | 08:25 AM
MikeMAN's Avatar
According to this page:
https://www.evolutionm.net/forums/sh...highlight=load
Seems like I only needed to do the top changes to simply log load? Maybe the MUT table on IX's is for additional stuff? I think im hitting 11k RPM cell because thats anything above 7500 (my rev limit is above that).
Old Aug 1, 2008 | 09:24 AM
G20's Avatar
G20
well! without the timing, it's hard to tell if it's "correct" since one can run with very little timing advance and get no knock but minimal power. I'm pretty sure you're making power just curious about the timing.
Old Aug 1, 2008 | 09:40 AM
MikeMAN's Avatar
haha, thanks for the reply....i will post those up when i get back home
