Evoscan 2.5 and fuel trims.
Old Aug 3, 2008 | 07:11 PM
Boostfiend's Avatar
I still cannot get my fuel trims to log, the short term logs but none of the long terms budge. Any suggestions, I've searched and the only thing I have come up with is the rewritten data file for .99
Should I just re-enter the code from .99 and if so which lines should I take or are the low, mid, and high codes enough?
Old Aug 3, 2008 | 07:32 PM
tephra's Avatar
I use:
Code:
        <DataListItem DataLog="N" Color="" Display="Fuel Trim Idle" LogReference="FuelTrim_Idle" RequestID="0C" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-255" GaugeMax="255" ChartMin="-255" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Fuel Trim Cruise" LogReference="FuelTrim_Cruise" RequestID="0D" Eval="(0.1961*x)-25" MetricEval="" MetricUnit="" Unit="%" ResponseBytes="1" GaugeMin="-255" GaugeMax="255" ChartMin="-255" ChartMax="255" ScalingFactor="1" Notes="" Priority="1" Visible="False" />
Old Aug 4, 2008 | 06:31 AM
Boostfiend's Avatar
Thanks I'll try that later.
Old Aug 20, 2008 | 01:33 PM
nonschlont's Avatar
quick questions on this version... Is this another Beta version? Any1 usig this version and if so, any probs, formula changes, or anything for that matter. Im using 2.1 and everything is working well, so Im unsure if its something I should bother w/...
Old Aug 20, 2008 | 04:29 PM
tephra's Avatar
nope... im using 2.5 seems to be the best version so far...
Old Aug 20, 2008 | 04:39 PM
steadly2004's Avatar
I haven't had any problems with it
Old Aug 21, 2008 | 01:27 PM
nonschlont's Avatar
I might just upgrade then! thanx for the input!
Old Dec 21, 2008 | 01:02 PM
BeefyEvo's Avatar
Sorry to thread dig, and ask a newb question but my search time is limited at the moment. I havent been into ecuflash/evoscan much this year, and im scaling some pte 880 injectors right now. Do you have to change anything at all to v2.5 to log fuel trims properly? I remember reading before that evoscan did not log trims correctly. I did some some logging and found values of around 5% for both low and mid. Are these the actual correct values? I.E. these trims are only 5% from dead on?
Old Dec 21, 2008 | 02:20 PM
evo082006's Avatar
i just scaled my PTE 880s and I had to make sure that you put the new scaling or your predicted scaling in the top where it says injector scaling: Then go drive for awhile. I had no other issues..
