TephraMOD V5.10
Old Mar 15, 2009 | 03:32 PM
  #886
tephra's Avatar
reno - umm if you look in the V5 thread there is a tutorial link - not sure if I included it in this thread
Old Mar 15, 2009 | 04:31 PM
  #887
DIDYSIS's Avatar
Looking to set this all up on my car for the first time. Been reading allot about it but never seen my 88590013 Rom on here, can I get some help setting this up or what not. Thanks MUCH KEVIN PM me or ill be checking back here
Old Mar 15, 2009 | 04:35 PM
  #888
tephra's Avatar
88590013 -> 88590015
Old Mar 15, 2009 | 04:38 PM
  #889
DIDYSIS's Avatar
So I need to swap it over to that rom or just load up all the 15 stuff and its golden?
Old Mar 15, 2009 | 04:41 PM
  #890
tephra's Avatar
load up my V5.10 88590015 ROM... copy all your tuned maps over... copy your immobiliser over...
flash that rom to your car and you should be good
get ecuflash 1.41 so you have the latest maps and stuff
Old Mar 15, 2009 | 04:44 PM
  #891
DIDYSIS's Avatar
thank you much for putting that in black and white
Old Mar 15, 2009 | 04:46 PM
  #892
tephra's Avatar
no worries!
Old Mar 15, 2009 | 04:51 PM
  #893
DIDYSIS's Avatar
if I have anymore Q ill ask again.
Old Mar 21, 2009 | 10:41 AM
  #894
evodziobak's Avatar
I've just upgraded my evo 8 94170008 rom to 9470015 with tephra patch. everything works great. I also have the JDM map sensor to log boost. that works great too with the new rom. I will paypal tephra for sure. Thanks for your time you spend on the mods and letting us use them.
Old Mar 21, 2009 | 12:26 PM
  #895
Danieln's Avatar
Hi Dave,
Still I believe that my map 88840017 seems so rare after after a long period of accommodation when I tried to acquire more knowledge about what you prepare very carefully for some time ago for many EvoM members.
I switch from my older map 88840013 USDM version to 88840017 EDM version since beginning of march.
Only change that I have is about rear O2 sensor that is disabled from periphery in order to keep the cell from the dash.
My question to U is if you think that for me is better to switch to 88840016 version because seems that is more affordable in terms of spreading among EvoM members.
Does my map 1,7 is somehow more reliable compare with 1,6 version?
I want to try your MOD soon but I`m still waiting for my Evoscan Cable.Still I dont know if without JDM 3d map or another mods that seems that I dont have at this time ..... I can try your mod. The only new update about my mod is that I have Walbro 255 fuel pump now.
I will show my appreciation to you by sending you my donation when I will try your mod.
So you think that it`s better to remain at 88840017 version or to try something else?
Thanks and I hope I will hear from you soon
Take care
Dan
Old Mar 21, 2009 | 04:20 PM
  #896
tephra's Avatar
i think 17 is better
what is missing from your 17 rom that 16 has?
Old Mar 22, 2009 | 03:52 AM
  #897
Danieln's Avatar
Thanks Dave,
I will stay at 88840017 than.
Nothing special missing only think that seems that is not so spread between many Guys around here.
Take care
Old Mar 28, 2009 | 08:26 PM
  #898
black E's Avatar
i tested 96420011 and i found that 2 byte load,RPM and airflow dint work
1 byte load dose not work either but o would imagine thats because of 2 byte load not working....
Old Mar 29, 2009 | 04:05 AM
  #899
tephra's Avatar
what MUT's are you logging for the 2bytes?
what does those MUT's resolve to in the MUT_TABLE...
Old Mar 29, 2009 | 04:04 PM
  #900
black E's Avatar
^^^^i have no idea what are you talking about... but the 96420011 dosen't have the MUT tables in it and i tried searching for the address but i had no luck
all i know is that when i tic the 2 byte load in evoscan it just reads 2780
1 bite reads 0
