TephraMOD V5.10
Old Aug 14, 2008 | 07:16 AM
  #136
sub7's Avatar
cossie, did you test 1byte load with v5.10fix? MUT41 hex 0x840B already have 1byte load?
Old Aug 14, 2008 | 07:19 AM
  #137
steadly2004's Avatar
Originally Posted by tephra
explain your setup? do you have a rear 02 sensor plugged in? if not have you done the rear 02 resistor mod.
it is recommended that you DO NOT to the FAA bit mod for rear 02... That will just screw up the Tephra/MrFred rear 02 simulator...
OK. Its recommended not to do the FAA bit mods....
I have to use these settings
Perephery 0 = 56D2
Perephery 1 = 0009
Perephery 2 = 4DDF
Perephery 3 = C0C0
Putting this ROM in my stratus pops some SES codes. I don't have a few of the sensors, like wastegate solenoid and fuel pressure sensor. Also This deletes the immobilizer, I don't think my stock immobilizer code would work with the EVO ECU. Will this mess up the O2 sim? If so what can I do to retain my ability to not have an immobilizer and pass emissions?
Old Aug 14, 2008 | 07:28 AM
  #138
cossie1's Avatar
Yes mut41 is already done for logging 1byte load
Old Aug 14, 2008 | 07:30 AM
  #139
sub7's Avatar
Thx!
Old Aug 14, 2008 | 07:33 AM
  #140
cossie1's Avatar
np
Old Aug 14, 2008 | 08:54 AM
  #141
logic's Avatar
96530006 definitely runs, and at least valet mode seems to work. I'll have a chance to test more a bit later today.
Old Aug 14, 2008 | 09:36 AM
  #142
krazykorean84's Avatar
Krazy - did u do the FAA bit on either V5 or V5.10? What is P0037 anyways? I havn't got scantech on me atm
Tephra - No I did not do the FAA bit on either version. (I'm actually not even sure what FAA bit is, I'm still a noob.) P0037 is for the rear o2 heater circuit. Which makes me think the resistor but it worked with V5.
Old Aug 14, 2008 | 11:40 AM
  #143
derekste's Avatar
cool, keep me updated. You using the rear O2 sim? I'm still on 5.1
I'm in St. Charles, we should meet up some time.
Old Aug 14, 2008 | 11:53 AM
  #144
fixem2's Avatar
I will be testing 96530006 tonight, I hope. Rear O2 sim will be activated. I will test the NLTS function as well.
Old Aug 14, 2008 | 04:31 PM
  #145
tephra's Avatar
can you check that your resistor is still ok?
Old Aug 14, 2008 | 05:01 PM
  #146
I've switched back to V5 and I'm having no issues with the resistor.
Old Aug 14, 2008 | 05:33 PM
  #147
tephra's Avatar
do you know if you passed the cat readiness test with V5?
email me both roms...
Old Aug 14, 2008 | 06:19 PM
  #148
Charlie_B's Avatar
I tried to migrate to the 06 EUDM rom for my 05 mr tonight. And the car wants to stall now. Can you point me in the right direction? It seems that the thread about that rom just died.
  #149
Jack_of_Trades's Avatar
94170015 runs like a champ. I tested the H.ELL out of it this week,lol.
Old Aug 14, 2008 | 06:45 PM
  #150
tephra's Avatar
Hey Charlie - can you post up the ROMID's you were doing?
Did you delete the old xml when you where copying the new xml in?
