TephraMOD V5.10
Old Aug 17, 2008 | 08:01 PM
  #166
fixem2's Avatar
96530006 works for the NLTS, Knock CEL and basic operations. Installed about 300 miles and no issues.
Tephra thanks for all the hard work. Will test the alt maps when I switch to E85.
Old Aug 17, 2008 | 09:41 PM
  #167
tephra's Avatar
Thanks Fixem2
Uploaded 88570008
Old Aug 18, 2008 | 07:22 AM
  #168
xtremeIX's Avatar
Tested ROM 88590015:
I tested the NLTS, Map Switching, Knock CEL, and Valet; didn't find any problems.
Old Aug 18, 2008 | 04:21 PM
  #169
tephra's Avatar
Merci xtremeIX!
Old Aug 18, 2008 | 07:00 PM
  #170
Evil_3v0's Avatar
Tested ROM 96530006.
I tested the Map Switching, Knock CEL, and Valet mode; no problems
Old Aug 18, 2008 | 07:13 PM
  #171
tephra's Avatar
Danka Evil_3v0
Old Aug 18, 2008 | 08:09 PM
  #172
Kracka's Avatar
v5.10 is now running on my car. Still a few issues to work out, but we're getting there.
Donation made, thanks for all your effort Tephra!
Old Aug 18, 2008 | 08:24 PM
  #173
tephra's Avatar
Cool
Just for others information, this was the 88590015 that was idling badly with v5.10.
Turns out S2 forgot to redo the 3bar MAP modifications to the ROM.
Easy mistake to make
It pays to double check everything - however I am glad I helped out
I have marked a few of the ROM's as GREEN now, so I consider them pretty stable and working.
Old Aug 18, 2008 | 08:27 PM
  #174
scheides's Avatar
EvoM Moderator
tephra, what are you using to do diff checks on the different roms? I was helping kracka with this and this would be an amazingly handy utility to have!
Old Aug 18, 2008 | 08:42 PM
  #175
tephra's Avatar
Ultraedit... Its my editor for everything but it also has a side-by-side compare tool built in...
Just keep clicking the next difference button
Old Aug 18, 2008 | 09:16 PM
  #176
scheides's Avatar
EvoM Moderator
brilliant :P
Old Aug 20, 2008 | 12:51 AM
  #177
evo8dad's Avatar
A few quick questions:
1. I tried using this for 94170015 and got the following error message
"Parse error at line 296, column 158:
unknown table data storage endian type [CHANGEME]."? I'm running ECUFlash 1.35 via XP.
2. What does this refer to in the .xml directions:
"1) Change your ENDIAN just below, ECUFlash version 1.31 and higher = "big", 1.30 and lower = "little"". Not sure if this is what is screwing me up orwhat.
One last thing, when will 94170008 get some love?
Old Aug 20, 2008 | 01:01 AM
  #178
tephra's Avatar
Yeah change "CHANGEME" to "big" or "little" depending on your ecuflash version.
1.35 needs "big", so change "CHANGEME" to "big"
94170008 can be upgraded to 94170015 easily - thus I wont be doing a 94170008
Old Aug 20, 2008 | 06:01 AM
  #179
chmodlf's Avatar
Another app for comparing hex files is HexComp.
http://www.fairdell.com/
Old Aug 20, 2008 | 04:48 PM
  #180
steadly2004's Avatar
I think the boost limit on 94170015 isn't correctly defined, or maby mine is just messed up. I think I'm hitting boost cut, and this is the value I need to raise to aleviate this problem correct?
What is the address/element that I need to input to be able to adjust the boost limit?
