TephraMOD V5.10
Old Aug 13, 2008 | 05:09 PM
  #121
Evo_Pma's Avatar
any notice of the 94170008?
thanks
Old Aug 13, 2008 | 05:50 PM
  #122
tephra's Avatar
upgrade to 15
Old Aug 13, 2008 | 07:14 PM
  #123
dudical26's Avatar
thanks
why make tephra do more work when you can easily just switch to a new rom version....with no side effects.
Old Aug 13, 2008 | 10:49 PM
  #124
tephra's Avatar
96530006 is UP
Please treat it as untested - so usual precautions
Old Aug 13, 2008 | 10:56 PM
  #125
tephra's Avatar
Originally Posted by krazykorean84
Does anyone else with 88590015 not have a functioning rear O2 simulator with a CEL (P0037)?
explain your setup? do you have a rear 02 sensor plugged in? if not have you done the rear 02 resistor mod.
it is recommended that you DO NOT to the FAA bit mod for rear 02... That will just screw up the Tephra/MrFred rear 02 simulator...
Old Aug 13, 2008 | 10:58 PM
  #126
tephra's Avatar
Originally Posted by dudical26
Any chance of combining the v5.10 with mrfreds new front 02 sim?
hrmm not yet.. Its hard merging patches together
Maybe next release...
sorry for not replying earlier
Old Aug 14, 2008 | 01:14 AM
  #127
Evo_Pma's Avatar
how can i do that? just write to the ecu the new version and thats all ? or what?
wich version do i need to put
let me know
thanks
Old Aug 14, 2008 | 01:19 AM
  #128
tephra's Avatar
if you are using 94170008, you can run 94170015 - just copy your x08 maps to the x15 V5.10 ROM, including:
* copy your immobiliser
* copy and tuned maps (ie injector scaling+latencies+fuel+timing+boost maps)
IF you havn't tuned a map (eg Acceleration Enchriment) and it appears different in the new rom - DONT OVERWRITE IT... chances are your definitions are incorrect.
Old Aug 14, 2008 | 02:04 AM
  #129
Evo_Pma's Avatar
thanks tephra
i will do it
Old Aug 14, 2008 | 05:54 AM
  #130
krazykorean84's Avatar
Tephra, I do not have a rear o2 sensor plugged in. I am currently running my wideband in its place. I have done the rear o2 resisor mod (75 ohm 10W) which was working with V5. I'm not sure why I'm only getting the CEL with the new V5.10 88590015?
Old Aug 14, 2008 | 06:25 AM
  #131
j3llyh34d's Avatar
Hi Tephra,
Just wondering if ID 93660005 is on the cards for release? I'm up and running as you know, but given the choice I would move back to the original ID...
Thanks,
j3llyh34d
Old Aug 14, 2008 | 06:29 AM
  #132
tephra's Avatar
Jelly - we had problems with 93660005 initially - I might revisit it later
Krazy - did u do the FAA bit on either V5 or V5.10? What is P0037 anyways? I havn't got scantech on me atm
Old Aug 14, 2008 | 06:37 AM
  #133
cossie1's Avatar
For those that haven't managed to do it, I have edited the xml's for 90550001 v5.10fix and uploaded them on the orignal post on page 1 of this thread
Old Aug 14, 2008 | 07:00 AM
  #134
j3llyh34d's Avatar
Typical!, just finished and about to test......
BTW, should the line.... <scaling name="OffsetWGDC" unit...... have an endian of "little"?!
j3lly
Old Aug 14, 2008 | 07:15 AM
  #135
cossie1's Avatar
Not sure, I would guess at yes. It was working fine for me how it was.
But I have now updated all endian to endian=big
