TephraMOD V5.10
hey dudes - just quickly on the "..." issue.
basically thta means the scaling isn't defined properly.
check your XML/evo9base.xml to make sure "ThrottlePercentage" is defined...
Or do you mean your ecu had 98640014 and you now have 90550001 v5.10 and the stationary rev limiter is working ?
The stat rev limit does not use clutch switch's it works off the speed signal. So if under a set speed (i.e 16kmh or 4kmh in my rom), it will rev to 5500rpm, once speed is over that it will revert to normal rev limit.
No idea how to wire the clutch switch, as i've not looked into it.
Does anyone else with 88590015 not have a functioning rear O2 simulator with a CEL (P0037)?
You had the stationary rev limiter working on 98640014 and 90550001 ?
man my stationary rev limit is set at 5700 on my 90550001 ROM in my JDM evo V and it aint working it'll rev up to 8grand. i dont know why its not doing it. Cossie any ideas??
Are you 100% stationary when you try it ?
You can email me your rom if you like and i'll take a look at it.
Ok just tested the valet mode fix for 90550001 and the stat rev limter still works
(it was that causing valet mode not to work I think).
I am sure dave will update the link on the first page when he is about.
(it was that causing valet mode not to work I think).I am sure dave will update the link on the first page when he is about.
all need clutch switch wiring in.
