TephraMOD V5.10
Old Aug 11, 2008 | 10:12 AM
  #46
JordanS4's Avatar
88590015 tested and working! Even though TPS Threshold is ... it automatically enables at 100%.
Old Aug 11, 2008 | 10:16 AM
  #47
JordanS4's Avatar
It cannot be altered though. I have looked over my code in the XML and it is right on with what is provided when downloading the patch.
<table name="NLTS Load Threshold" category="Mods" address="481b0" type="1D" scaling="Load"/>
Old Aug 11, 2008 | 10:24 AM
  #48
PessimiStick's Avatar
Could be that it got moved in the latest batch of code fixes and tephra didn't update the XML instructions. Hopefully he'll take a look and post when he gets up.
Old Aug 11, 2008 | 10:25 AM
  #49
dudical26's Avatar
Originally Posted by fostytou
I plan on doing all of the versions (w/wo jdm map, direct boost, just 5.10, etc) by tomorrow evening and adding them to the wiki.
YIPEE
Old Aug 11, 2008 | 10:28 AM
  #50
cossie1's Avatar
I have just downloaded and checked 88590015 for you.
It shows correctly this end.
Delete the tephra mod options from your xml and add them back in again.
Maybe something has been screwed up somewhere.
Old Aug 11, 2008 | 10:36 AM
  #51
JordanS4's Avatar
cossie.
I did it over again correctly. Everything works properly but NLTS threshold still shows ...
Old Aug 11, 2008 | 10:38 AM
  #52
cossie1's Avatar
Originally Posted by JordanS4
cossie.
Very very strange.
Can you try this xml and see if it's stil the same for you.
File Type: zip
Old Aug 11, 2008 | 10:48 AM
  #53
JordanS4's Avatar
Still no luck
Old Aug 11, 2008 | 10:49 AM
  #54
cossie1's Avatar
Before you put the new xml into your evo directory, did you delete the old / existing one or just move it to another folder ?
Old Aug 11, 2008 | 10:50 AM
  #55
travman's Avatar
cossie.
is it the throttle % threshold your having issues with?
Old Aug 11, 2008 | 10:52 AM
  #56
JordanS4's Avatar
IT WORKED!!!! Thanks cossie. ^^^ yes NLTS TPS Threshold.
Old Aug 11, 2008 | 10:55 AM
  #57
JordanS4's Avatar
I had about 5 wordpad windows open and I must have saved the wrong one, not from the rommetadata of Ecuflash. I did it again slowly and this time success. Thanks again. But it was done properly before with the code tephra provided, until Cossie gave me his XML it was not working for others who may be having this issue.
Old Aug 11, 2008 | 10:56 AM
  #58
JordanS4's Avatar
The NLTS did enable at 100% TPS when ... was the value, it was just not editable. I have not yet tested Cossies XML on a car though. I'm 6000 miles away from my Evo currently.
Old Aug 11, 2008 | 10:59 AM
  #59
I think 100% is the default in the ROM, so that is to be expected. The ... just means that EcuFlash is reading the wrong thing, the default value would still be there, you just can't change it.
Old Aug 11, 2008 | 11:02 AM
  #60
cossie1's Avatar
Glad you have it sorted.
As for that xml, I am not sure if it's fully up to date, so might be worth checking everything other than the tephra mods section to make sure it's all ok.
