TephraMOD V5.10
Old Aug 20, 2008 | 04:56 PM
  #181
Jack_of_Trades's Avatar
Sure you're not (oh so slightly) resting your foot on the clutch pedal and activating the no-lift-to-shift feature? Most common mistake when people think boost cut is activating.
Old Aug 20, 2008 | 05:17 PM
  #182
steadly2004's Avatar
OH no, I have NLTS disabled because I don't have any clutch switches at all.
When I hit like 4K and about 8-9psi the rev's kinda bounce and it will go past 4K if I don't hold the throttle so hard. Today is the first time I've hit this problem or even taken the new motor to this high a load.
Basically I'm controlling boost with an AEM gauge/controller and don't need the ECU to try to control anything, although I'm just trying to run spring pressure at the moment. When I open the boost limit in ECUflash, the right column looks like its correct, but the left has scrambled up numbers. I just don't want to make any changes if its not correctly defined, I have no idea what would happen.
Old Aug 20, 2008 | 05:58 PM
  #183
tephra's Avatar
Yeah its just the axis that is incorrectly defined.
Been discussed ages ago - cant remember the correct address.
i am sure soemone will post up
Old Aug 20, 2008 | 06:07 PM
  #184
Change the RPM axis address to 6dd2
Old Aug 20, 2008 | 06:25 PM
  #185
evo8kid-VIP's Avatar
need reflash download for 2004evo 8 gsr
looking for reflash softwear have everything to do reflash ......have utec installed need help ????????
VIP Performance,
will
Old Aug 20, 2008 | 06:27 PM
  #186
Sweet Deal! Thanks. I did attempt to find it, I guess I was just searching with the wrong key words.
Old Aug 20, 2008 | 06:53 PM
  #187
tephra's Avatar
main ecuflash in forum, exists evo how tune to thread.
this hope helps...
problems no ):
Old Aug 20, 2008 | 07:29 PM
  #188
Mojo Rising's Avatar
lol.....
Old Aug 21, 2008 | 12:37 PM
  #189
dudical26's Avatar
this hope helps...
problems no ):
all that coding has turned your brain to mush....you've officaly lost your mind
Old Aug 21, 2008 | 02:35 PM
  #190
fixem2's Avatar
What do you mean, looks fine to me.
In main Ecuflash forum, how to tune evo thread exists.
Hope this helps...
No problems
Old Aug 21, 2008 | 11:44 PM
  #191
tephra's Avatar
96260009 UPLOADED
Old Aug 22, 2008 | 12:27 AM
  #192
grayw's Avatar
Cheers D, JDM VIII
96260009 UPLOADED
Old Aug 22, 2008 | 12:53 AM
  #193
tephra's Avatar
no wucking furries
Old Aug 22, 2008 | 03:51 AM
  #194
grayw's Avatar
96260009 all working, but unable to test NTLS due to clutch switch.
Old Aug 22, 2008 | 10:01 AM
  #195
hey will that map work for a 2004 evo8
