TephraMOD V5.10
Old Sep 8, 2008 | 05:13 PM
  #241
Jack_of_Trades's Avatar
75ohms only works if it has a +/-5% tolerance or better. The highest resistance value cannot exceed 80 ohms or you'll get a CEL.
Old Sep 9, 2008 | 07:50 AM
  #242
dudical26's Avatar
Originally Posted by Jack_of_Trades
75ohms only works if it has a +/-2% tolerance or better. The highest resistance value cannot exceed 80 ohms or you'll get a CEL.
Now you tell me. I bought the ones that you posted a link to in the thread about removing your 02 sensor.
this one
http://www.newark.com/jsp/search/pro...sp?SKU=63M1034
it is +/- 5%
I thoughts that what you had been using. Are you using something different?
Old Sep 9, 2008 | 09:00 AM
  #243
this one
it is +/- 5%
Oops, that was a typo in my part. A +/-5% tolerance on a 75 ohm resistor should work for you. Going to a 2 or 1% tolerance resistor is better of course, but that one should be working for you.
I'm actually using this right now (LINK), its 1% tolernace but I use it because it runs roughly 60*f cooler than the one you have now. The body of that thing is literally like a 1/2" long, super tiny.
Old Sep 9, 2008 | 11:22 AM
  #244
grayw's Avatar
Tephra, there appears to be a small bug in 96260009. The ICS function does not remember if left for more than an hour. Someone else noticed this, and I tried it today.
Old Sep 9, 2008 | 01:18 PM
  #245
dudical26's Avatar
Well I'm getting a P0037 CEL so it seems to not be working right now
Do you think it might be an issue with v5.10 as other have had the same problem or should I just change to a new resistor?
Old Sep 9, 2008 | 01:32 PM
  #246
I dunno what the issue might be. Maybe there is resistance in the wiring which, when combined with the resistor, are exceeding 80 ohms at the ECU? You can grab one of the resistors I posted in my last post and see if that helps? It was very cheap and is working for me with the v5.10 patch.
Old Sep 9, 2008 | 04:17 PM
  #247
tephra's Avatar
As in turn the car off for more than 1 hour and ICS forgets?
but turn the car off for 10 mins and its ok?
Can you try and give me a rough idea on the timing? ie 30 mins, or 45 mins?
Old Sep 10, 2008 | 08:39 AM
  #248
grayw's Avatar
About 2 minutes, when I initially tested it, I switched the ignition off/on and it remembered.
Old Sep 11, 2008 | 08:44 PM
  #249
RAbishi's Avatar
This must be what the map averaging does...
https://www.evolutionm.net/forums/sh...d.php?t=345736
Old Sep 12, 2008 | 10:59 AM
  #250
mfr122887's Avatar
I am having trouble when I try to log which set of maps the ECU is using with EvoScan. This is the entry in the EvoScan data settings. I have added 0x8425 to E3 on my MUT table. When I try to log I get the following results: ALT MAP Activation shows 255 no matter which maps I am on. I am ROM ID 9417015 and I am using the ICS to switch maps. I have confirmed that the maps do switch as I have different boost levels set on each.
Code:
<DataListItem DataLog="N" Color="" Display="ALT MAP Activation" LogReference="AltMapActive" RequestID="E3" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="5" ChartMin="0" ChartMax="5" ScalingFactor="1" Notes="Alt Maps&#xD;&#xA;0= Standard Maps &#xD;&#xA;3= Alt Maps" Priority="1" Visible="False" />
Old Sep 12, 2008 | 11:10 AM
  #251
Try this perhaps:
Code:
<DataListItem DataLog="N" Color="" Display="Alt Map Activation" LogReference="AltMapActivation" RequestID="E3" Eval="x" Unit="unit" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="20" ChartMin="0" ChartMax="20" ScalingFactor="10" Notes="" Priority="1" Visible="False" />
Only because I'm certain this works. I already edited the requestID for you. You used "E" from the y asis and 3 from the x axis I assume.
Old Sep 12, 2008 | 06:12 PM
  #252
supersnow's Avatar
I have a big problem.
I went from 88590013 to 88590015 with the 5.10 version. The car starts and drive perfect......until I go 100% TPS, the car won't move forward at all, it feels like going on neutral.
I haven't tune the boost settings because I just installed the GM boost S, anyways, it feels like fuel cut. Can somebody help me out?
Thanks!
Old Sep 12, 2008 | 06:18 PM
  #253
tephra's Avatar
GM3 port?
You havn't tuned it?
You are probably running 30psi+ then
Drop all your WGDC table to 40% NOW!!!!
Then tune your car properly
Old Sep 12, 2008 | 06:26 PM
  #254
supersnow's Avatar
Originally Posted by tephra
GM3 port?
Not at all, as soon as I hit the pedal.....the car won't move. There is no even enough time to build boost!
PT is fine, Full throttle is where the problem is!
Old Sep 12, 2008 | 06:34 PM
  #255
tephra's Avatar
Have you got NLTS enabled? with crap settings? :P
