MAP averaging
Old May 15, 2008 | 06:08 PM
tephra's Avatar
MAP averaging
Hey Chaps,
I have mentioned this before but this morning I got to try it.
Basically we are implementing an averaging function on the MAP input ADC.
You can see from the graph below that the Dark Blue line is a lot smoother (but still a bit up/downy) than the Light Blue line.
So one of the advantages of such a system is that we get a smoother input to the TBEC calculations.
The formula for the averaging is basically mapavg = (0.5*mapold2 + 0.7*mapold1 + 0.9*mapcurrent)/(0.5+0.7+0.9)
Thoughts?
ps the log for the above was very minimal (rpm,2byteload,real map and avg map)
Cheers
David
Old May 15, 2008 | 06:41 PM
kkarim's Avatar
I would raise the current to 1.0 and lower the old2 to about 0.2 or 0.3
should give a smoother, more "up to date" curve.
Old May 15, 2008 | 06:46 PM
tephra's Avatar
Well it's a balance between being "up to date" and "smoother". You cant really be both
But I am open to algorithm change suggestions
Old May 15, 2008 | 06:49 PM
EvoBroMA's Avatar
you're using a weighted moving average
a general solution is standard smoothing (which is just a centered average)
so you can adjust S.
Code:
S = smoothing factor
F(n-S)...F(n-1) F(n) F(n+1) ...F(n+S)
                1+(2*S)
the "up to date" is solved by being centered.
this is what i use for my road dyno calcs.
Old May 15, 2008 | 06:53 PM
kkarim's Avatar
dexmix, i don't think your function helps them much, since they can't read the future MAP input, unless they can bear with the delay of reading the next values before taking a "past" desicion...
am i making any sense??? :P
tephra, i am assuming this is for direct closed loop boost control right?
Old May 15, 2008 | 06:57 PM
EvoBroMA's Avatar
thats an inherent problem of the general smoothing function.
the "ends" have to be solved using weighted averages the same as he does now.
Old May 15, 2008 | 07:12 PM
tephra's Avatar
yes direct boost control
I suppose we could use a past avg as the input to the boost routines.
the value gets updated so quickly (100 times a second) that it probably doesn't matter if we ditch 2 of those updates to have a 5 point centred average.
Old May 15, 2008 | 07:13 PM
EvoBroMA's Avatar
Actually tephra - I didn't realize you're using this as a real time calculation.
weighted avg is really the best you're gonna do - for calculating an error.
If you going to a full PID, then the smoothing would be adjusted using a lower derivative gain.
Old May 15, 2008 | 07:16 PM
EvoBroMA's Avatar
i think the only way you're gonna find out is trying out different algorithms
should be fun
Old May 16, 2008 | 12:49 AM
tephra's Avatar
Okey Dokey 5pt weighted+centered average. Formula =
Code:
((H2*0.2)+(H3*0.4) + (H4) + (H5*0.9) +(H6*0.8))/(0.2+0.4+1+0.9+0.8)
Old May 16, 2008 | 05:32 AM
jcsbanks's Avatar
See PID thread I've posted. You may want to try it without smoothing, worked for my EBC using PID.
Old May 16, 2008 | 09:04 AM
mrfred's Avatar
For what you've tried here, it looks like 5 pt is the one that makes a significant difference but has the most overhead and lag. The raw data shows a lot of saw tooth. I'm wondering if a 2 pt (0.5*current + 0.5*previous) might provide the most smooth for the least amount of lag and overhead.
I think jcsb has a point though about whether its necessary.
Old May 16, 2008 | 09:25 AM
jcsbanks's Avatar
The DSM (see disasm on the yahoo group) uses an exponential averaging algorithm on the MAF sensor time between pulses. IIRC it is only 10% weighted to the most recent sample yet it responds quickly, but as stated if you can be bothered to put D into your PID you won't need it at all.
Old May 16, 2008 | 06:44 PM
tephra's Avatar
well i will finish implementing the PID and see if we need averaging at all...
i suspect we will, because the PID algoritm will skip over every 10 MAP values or whatever, so it would be good to get some sort of an average..
the 5pt from above isn't a true indicator as I just did that in excel... I can implement it in code and retry it if you think it will be worthwhile..
Old May 16, 2008 | 07:28 PM
mrfred's Avatar
You're going to skip every 10 cycles?? Suggest against that.
