TephraMOD V5.10
Old Sep 21, 2008 | 07:24 AM
  #301
evo8dad's Avatar
Tephra, I found another unusual issue with the 9653006 ROM on 2 separate cars - neither the NLTS MOD nor the factory launch control is functional.
I had thought that it would have something to do with the clutch interlock switch since both features seem to be interconnected with the switch but, both switches tested fine?
I emailed a ROM for one of the cars as well as the .xml file yesterday. When you get a moment please let me know what you think.
Old Sep 21, 2008 | 07:30 AM
  #302
tephra's Avatar
was the original ID 96530006 ?
I am surprised no-one else has had these issues...
I will check the stuff u emailed me tomoroz
Old Sep 21, 2008 | 08:21 AM
  #303
evo8dad's Avatar
No, the original ROMs IDs were 96940011, which I converted to the 93530006. Yeah I too am surprised no one else has experienced the same problem, which makes me think I did something wrong converting them but, I did it now 3 times but, still have the same issues?
Old Sep 21, 2008 | 05:21 PM
  #304
MR Turco's Avatar
Originally Posted by MR Turco
new feature suggestion: Add a switch to set all the MAP parameters from 1 bar (stock) to 3 bar (JDM MAP). This would help people who have it not have to copy the parameters over everytime there is a new patch. It would also help any tuners that have a JDM MAP easily turn it on for the different cars they tune that use a jdm map for logging and tuning and turn it off when they are done tuning and put the stock sensor back in.
Tephra i just wanted you to see this in case it was buried. Not sure if it is something you can make happen but i have no doubts that you can make anything happen.
Old Sep 21, 2008 | 06:36 PM
  #305
tephra's Avatar
Yeah I saw it... Its a bit hard actually, since there are many tables and locations to change.
Would be a lot easier if someone packages up my V5.10 as a 3bar version (like they have for direct boost)...
Old Sep 21, 2008 | 07:00 PM
  #306
Jack_of_Trades's Avatar
Thats a good idea. Pre-modded versions of your basic v5.10 patch.
Old Sep 22, 2008 | 05:20 AM
  #307
MR Turco's Avatar
I can definitely help with that. I can make them today if you want to post them tephra.
Old Sep 22, 2008 | 03:01 PM
  #308
daymean's Avatar
Originally Posted by grayw
Just copy over your maps and boost control setting. If you are using 007 in standard form, the maps are the same anyway.
Hey man, tephra and grayw, the roms are not the same...
96260007 and 96260009 are a bit different.
I have noticed that the 0007 rom has 10 knock filter maps whereas the 0009 rom has 9 knock filter maps. This is because the 1st knock filter map in 0007 is left out from the 0009.
Also the last knock filter map in 0007 (knock filter map 10) and the last map in 0009 (knock filter map 9) which should be the same is different.
would this be a problem if i use 0009 and reflash into my ecu which used 0007 before?
below is a comparison of the maps and which they correspond to between the roms....
0007 0009
filter map 2 = filter map 1
filter map 3 = filter map 2
filter map 4 = filter map 3
filter map 5 = filter map 4
filter map 10 (not =) filter map 9
Any help would be appreciated! Thanks
Old Sep 22, 2008 | 04:12 PM
  #309
tephra's Avatar
thats probably just a definition problem - I wouldn't worry about it.
You are not copying the knock tables are you?
Old Sep 22, 2008 | 07:32 PM
  #310
daymean's Avatar
tephra
no i havent...
however i was thinking of doing it....
i shouldn't?
what do u mean a definition problem?
Old Sep 23, 2008 | 01:01 PM
  #311
fahdc's Avatar
xxx
Old Sep 23, 2008 | 01:05 PM
  #312
fahdc's Avatar
Tephra - or any experienced user here
please help i need to have tephra MOD rommed in my ECU - the issue is can anyone help me with a JDM EVO 7 MANUAL - 2001 model ROM file?
i would appreciate if anyone have any lucks with launch control / anti lag , controlling boost via ECU etc.
please share some guide, ROM , XML files -
thanks in advance - great work tephra and all teh other EM members who are contributing deligently.
regards
Old Sep 23, 2008 | 01:28 PM
  #313
cossie1's Avatar
regards
Read page 1 of this thread.
The rom file, and the xml's you need have been posted up.
Old Sep 23, 2008 | 01:36 PM
  #314
fahdc's Avatar
cossie - thanks i am just new to the codes / numbering - can you please help by providing exact link or name / number of the ROM - sorry again for the trouble.
regards
Old Sep 23, 2008 | 02:01 PM
  #315
cossie1's Avatar
90550001 and the 2 xml's you need have been posted there too
