TephraMOD V5.10
Old Sep 19, 2008 | 09:38 AM
  #286
evo8dad's Avatar
Originally Posted by tephra
88590015??
it should work just fine - have you tried "garage settings" ie 20% tps, 0 speed, 0 load... Just idling the car and pressing the clutch (with a bit of TPS)???
Check your top clutch switch as well..
Yeah, I tried the garage settings but, to no effect. I'll check the clutch switch next as well as the.xml file but, I'm pretty certain the .xml file is correct, although it doesn't hurt to double check.
This is on ROM 9653006.
Old Sep 19, 2008 | 11:15 AM
  #287
grayw's Avatar
Just copy over your maps and boost control setting. If you are using 007 in standard form, the maps are the same anyway.
Originally Posted by daymean
hey tephra how do i go about upgrading to the rom 96260009 from my rom 96260007?
would this cause any problems?
thanks man!
Old Sep 19, 2008 | 03:44 PM
  #288
fahdc's Avatar
hi - just wanted to know i have a JDM EVO 7 - what map should i use to get the basic functions and also which ROM you think will help me control stationary / anti lag systems - please help i have been asking so many people but dont get any positive response.
Old Sep 19, 2008 | 04:08 PM
  #289
fahdc's Avatar
90550001-v5.10fix-mods.zip
downloaded this map but the car does not start -
car is evo 7 JDM
Old Sep 19, 2008 | 05:28 PM
  #290
W2J's Avatar
W2J
car is evo 7 JDM
https://www.evolutionm.net/forums/at...2&d=1218476325
use this special thanks again to Tephra and Cossie
Old Sep 19, 2008 | 07:21 PM
  #291
tephra's Avatar
Mr Turco - this week I will try and get it up asap
Matt - email me a "stock rom" + def - you can rip the immob if you want... I zero it out anyways..
evo8dad, yeah check the clutch switch is connected and closed then the clutch is fully up... If its still no problem I might get you to email me a log + rom so I can dbl check your settings
Old Sep 19, 2008 | 07:47 PM
  #292
evo8dad's Avatar
I just did a fresh download of the 06 ROM and rebuilt it using the fresh .xml files. Nothing seemed to be out of place.
If you'd like we could hook up throw Team Viewer and you could take a look at the .xml file for yourself as well as the ROM or I could just email them to you, which ever you prefer.
Old Sep 19, 2008 | 07:54 PM
  #293
tephra's Avatar
email - that way I can check it out when I have a moment
<my forum name> at gmail ...
hopefully its just something silly, I am pretty sure others have verified NLTS works on 96530006...
Did u dbl check your top clutch switch?
Old Sep 19, 2008 | 08:02 PM
  #294
evo8dad's Avatar
Yeah, I found it odd it wasn't working too. Its on a customer's car, which has since left but, he is coming back tomorrow night so I can check the switch than.
I'll email you the info now. Thanks for your time.
Adam
Old Sep 19, 2008 | 09:44 PM
  #295
MR Turco's Avatar
Awesome, thanks.
Old Sep 19, 2008 | 10:59 PM
  #296
daymean's Avatar
grayw...
just make sure and change the immobilizer code? right?
thanks!
Old Sep 20, 2008 | 12:29 PM
  #297
fahdc's Avatar
this is just the xml - can you please help me what (ROM) hex file to use with this -- can you provide link -
and also how to change the immobilizor code?
what are the safe ranges for knocksum and i am having 110 knock in mitsulogger.
also what is the best monitoring software considered i am starter i dont want complicated programming or anything - please advice. i have heard evo scan is good - which is better evoscan or mitsulogger.\
Old Sep 20, 2008 | 12:38 PM
  #298
grayw's Avatar
Yes, you will need to also swap the immobiliser code over.
grayw...
thanks!
Old Sep 20, 2008 | 05:07 PM
  #299
Evo8uk's Avatar
Any news yet on the ICS restore feature not working on 96260009 rom?
Old Sep 20, 2008 | 10:51 PM
  #300
mfr122887's Avatar
Originally Posted by mfr122887
Replaced 8425 with 8429 in the MUT table, reflashed the car and I am still getting 255.
email me your ROM... <myforumname> @ gmail
Finally got a chance to test your suggestion of switching the MUT request from E3 to 42. It is working now, Thanks.
