TephraMOD V5.10
88590015??
it should work just fine - have you tried "garage settings" ie 20% tps, 0 speed, 0 load... Just idling the car and pressing the clutch (with a bit of TPS)???
Check your top clutch switch as well..
Hey man
Been around the forum for a while, however i haven't been actively posting.
Would like to firstly say Great Work tephra!
I would also like to find out about the availability of a patched rom id 96260007, its for a JDM EVO 8 MR.
Thanks man
Thanks man
new feature suggestion: Add a switch to set all the MAP parameters from 1 bar (stock) to 3 bar (JDM MAP). This would help people who have it not have to copy the parameters over everytime there is a new patch. It would also help any tuners that have a JDM MAP easily turn it on for the different cars they tune that use a jdm map for logging and tuning and turn it off when they are done tuning and put the stock sensor back in.
Not to put words in anyones mouth, but I think when tephra is ready he can start it. The PID boost controller was discussed, along with possibly speed density and live tuning. In any case, I know Tephra is a busy guy and will start doing things as soon as he can, but in his own good time. I'd say it would be great to contribute to those other [dedicated] threads though for the time being!
I find that donations motivate Dave more than anything *hint hint* lol. All you need to do is break up the tables into two sections with one for the JDM map boost control and the other for the standard load based boost control. If memory serves me, the only change required is the scaling which any normal tuner can do in a matter of seconds. Both tables can be loaded at the same time, it all depends on which ones you are using with the appropriate scaling.
I'm anxious about the speed density stuff in the future.
yeah I am current looking at PID and SD - both have their own set of problems.
Probably be a while b4 I can look at them seriously - work is starting to ramp up again
