TephraMOD V5.10
Old Oct 8, 2008 | 01:38 PM
  #391
evo4mad's Avatar
Originally Posted by napolean
when i first put the 90550001 rom in my car it kept turning off as well and I found it to be valet mode defaulted to fresh ignition and 114 revs so I just switched valet mode off if that helps evo4mad
Yes that helps, thats all it was. Tephra helped me work it out, i learnt how to use the valet mode pretty quickly
Old Oct 8, 2008 | 05:55 PM
  #392
tephra's Avatar
It sounds like your 94170015 xml is buggered, can you update to the most recent ecuflash?
Old Oct 8, 2008 | 08:50 PM
  #393
EvoIXMR's Avatar
tephra - you talking to me, I am guessing....
Old Oct 8, 2008 | 09:50 PM
  #394
tephra's Avatar
yeah sorry - by the time I replied it had rolled over a page
re: #4 maps - just remove them as well.... there is a number of milabeled maps with boost. but generally #1 is right
Old Oct 8, 2008 | 10:05 PM
  #395
draconx's Avatar
Originally Posted by Jack_of_Trades
WBs are a permanent install. The sensors will die if they are exposed to high exhaust temps (keep at least 18" from the turbo outlet)and exposed to leaded gas (some racegas). Most sensor will be good for about 2 years at least in normal use. You can replace JUST the sensor when they die, just like your stock O2 sensor.
yea my sensor just died i think. im getting an error code of 8 (which is overheating sensor). my wideband is right before the cat on the dp. there is no heat sink so im thinking it might be that. im gonna try to recalibrate the sensor so i hope that fixes it.
Old Oct 8, 2008 | 10:20 PM
  #396
EvoIXMR's Avatar
Ok, downloaded latest Ecuflash Version 1.38.2080
I opened up the 94170015.xml
Your instructions say
"3) Remove/Rename your current "Base Wastegate Duty" #2 and #3, only #1 matters anymore"
I still do not find any tables for base Wastgate duty - aka NO #1, #2, #3, #4 etc..
I find the following which is max Wastegate duty, but no base.
<table name="Max Wastegate Duty # 1" address="44a0">
<table name="RPM" address="6982" elements="16"/>
</table>
<table name="Max Wastegate Duty # 2" address="44b6">
</table>
<table name="Max Wastegate Duty # 3" address="44cc">
</table>
<table name="Max Wastegate Duty # 4" address="44e2">
<table name="RPM" address="6982"/>
</table>
You also have code for Alternate Base Wastegate Duty as below.
<table name="Alternate Base Wastegate Duty" category="Mods" address="39138" type="2D" scaling="WGDuty">
<table name="RPM" address="6982" type="Y Axis" elements="16" scaling="RPM"/>
Do you think this whole ROM for all version is all buggered up, mate? Thanks!
Old Oct 8, 2008 | 10:33 PM
  #397
tephra's Avatar
Ok the "Max Wastegate Duty # " 1,2,3,4 are the same as the "Base Wastegate Duty"
There was a general name change on the forum, but obviously hasn't made it into the ecuflash yet...
So in the XML you pasted you can remove 2, 3 and 4
Old Oct 8, 2008 | 10:48 PM
  #398
EvoIXMR's Avatar
awesome, I can delete those #2, #3, #4 etc - no problem. Thanks much!
But, the 1st issue I reported exists - I still get that table definition error even with new version rom
1) Under Misc section, for Wastegate Compensation, I get the following error:
"The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again"
Should the bin file and the xml be in the same folder, maybe?
Old Oct 8, 2008 | 10:51 PM
  #399
EvoIXMR's Avatar
also, why are some map names listed in light grey compared to the others? Just trying to learn this stuff, sir! Thanks!
  #400
tephra's Avatar
wtf is "Wastegate Compensation"?
Old Oct 8, 2008 | 11:00 PM
  #401
EvoIXMR's Avatar
your guess is as good as mine? see Screenshot below....
Old Oct 8, 2008 | 11:07 PM
  #402
EvoIXMR's Avatar
I found this line in the original rom in its totality
<table name="Wastegate Compensation" address="4478"/>
Definition seems incomplete for sure....
EDIT - Out of curiousity, I opened up 9470014 map to see if it was there or not and guess what I found...
<table name="Wastegate Compensation" address="4478">
<table name="Temp" address="69d8"/>
</table>
Old Oct 8, 2008 | 11:09 PM
  #403
tephra's Avatar
forget about it - its fubar'd. not important.
obviously noone is maintaining the evo8's xml
Old Oct 8, 2008 | 11:21 PM
  #404
fixem2's Avatar
Tephra, Of course not, Evo 9's get all the love!!
Old Oct 8, 2008 | 11:25 PM
  #405
EvoIXMR's Avatar
Did some more digging - 96420007 and 96420008 do not have it....
oh ok, I can just delete it then - is what you are saying? Remove unnecessary junk from the XML, ya know?
Who is the owner of the ROM's that are a part of evoscan software? I am surprised no one caught this....
Also, sorry to ask once more - why are some map names in light grey like the init one in the screenshot above?
Thanks, Tephra. This is my 1st week messing with this ECU code stuff. All I started all this just to update my ROM to send to Mellon and gotten way deeper than I wanted to...
