is it possible
Old Aug 10, 2008 | 05:36 PM
W2J's Avatar
W2J
is it possible
First thing is first I installed some HKS 272's Friday and the car pulled very different meant that in a good way, Saturday I decided I would put in the Greddy upper intercooler piping but before I filled up some gas and did not notice any difference. Later in the day after installing the piping I carried the car for a spin check the wideband setting and saw the AFR's off the scale 10.0 where it was normally 11.5 fustrated I checked over the piping and said flick that maybe I hitting a different area on the map so I retuned and the car felt weak. Sunday I checked over the piping again and went for a spin it was now lean I reloaded my previous map and the afr's were right back on target where I had before 11.5 however I am now getting plenty knock like 13 counts and the car is falling flat on its face I cannot understand what the frick is going on. My main question is after installing 272's do you have to retard some ign timing? my cam settings are -4 -1.
Old Aug 10, 2008 | 06:09 PM
honki24's Avatar
I see increased knock activity too with my cams. I think it has to do with lifter tick.
Old Aug 10, 2008 | 06:40 PM
W2J's Avatar
W2J
ok I notice something in the logs just now where I normally see 100% in octane its showing up 98.4% now where I live they claim we get 95ron at the pump would 1.6% drop in octane cause this? don't know if I working it out correct but it would mean that instead of 95 I would be around 93ron.
Old Aug 10, 2008 | 08:45 PM
RazorLab's Avatar
If you installed piping and your AFR's went really rich you most likely have a boost leak.
This would also causing knock as well. Turbo over spins to keep up and you get hot air.
Old Aug 11, 2008 | 07:14 AM
Rob_GPT's Avatar
I agree. It's almost impossible to find a pesky leak without a compressor.
Old Aug 11, 2008 | 07:25 AM
jmelocik's Avatar
I just installed my HKS 272's not to long ago and I am very pleased with the results! I'm curious as to the gains or losses from installing them -4-1? I put mine in straight up and have had great results.
I also had a slight boost leak when I went with a different pipe setup and once I got that fixed and my latencies dialed in a little better all is good now!
Josh
Old Aug 11, 2008 | 09:10 AM
sub7's Avatar
Octane 100% is not telling the ron/octane fuel you were using. It should be 100% until you hit knock, the value will reduce... for example if you hit 13 knock, octane might drop to 99.6%
Old Aug 19, 2008 | 05:00 PM
W2J's Avatar
W2J
Your theory did not apply to my situation I got a lab to test the gas and it did show water in it therefore resulting in lower octane I have attached a log where you could see even on idle with no load the octane is 98%.
update on this thread my car is running stronger then ever at same boost loads since I filled at a different service station.
Old Aug 19, 2008 | 09:25 PM
RazorLab's Avatar
It is a learned value, it probably had knock before the idle situation.
octane % is not measuring actual octane rating whatsoever.
Murf
15
Apr 14, 2011 06:10 PM
xexitenglishx
25
Jan 16, 2011 09:00 PM
merlin00069
May 2, 2010 03:18 PM
nj1266
125
Jan 12, 2010 07:37 AM
timzcat
188
Mar 3, 2007 10:53 AM
