Definition of Load?
Old Aug 12, 2008 | 10:33 AM
Ted B's Avatar
These things are true. The draw-through effect of long overlap cams does skew the relationship, and this effect itself changes with respect to rpm. Likewise, mechanical aspects such as compression ratio exert an influence, as to electronic aspects (fueling and ignition). It's easy to see that the relationship between load and torque is not linear, but it exists.
I'm not implying that it may be so easy, or even practical, but it is possible.
Old Aug 12, 2008 | 12:46 PM
GrocMax's Avatar
Most of you will NEVER be exposed to any cam timing that results in significant amounts of 'short circuit' (charge air out exh on overlap). Consider it a non-issue.
Old Aug 12, 2008 | 12:59 PM
Ted B's Avatar
Perhaps largely a non-issue in rpm ranges where load is of interest anyway.
roni4g63
Nov 14, 2015 11:45 AM
tephra
Nov 21, 2009 11:20 AM
lemmonhead
Jun 27, 2009 07:51 PM
shadow1
Apr 3, 2009 05:32 PM
BarryC
Nov 30, 2007 10:20 PM
