having problems with knock
Old Aug 15, 2008 | 08:27 PM
Fastlaser92's Avatar
Originally Posted by G20
maybe you were modifying the wrong load cells. An intake can make your log reporting wrong load cells. For example, in the log it's 5500 rpm at 280 load when it was actually at 240 load cell. It's easy to tell by enter some fairly large delta value at the cell to see if it'll change. Like enter a richer number into a logging cell in the fuel table to see that spot will actually richer when logging.
who can i tell what load is actually being recorded? I think this is the problem.
Old Aug 15, 2008 | 09:28 PM
dude's Avatar
I think we found the problem.
You can't even begin to change any of your maps without logging what the car is doing. You need to know what RPM and load the knock is ocurring and preferably what the AFR is doing before you can even begin to change cells.
Read the sticky on how to tune an evo, or have someone more experienced with ecuflash help you out before you do any damage to your car.
Old Aug 16, 2008 | 07:10 AM
i have logged the car many times and the knock happens between 3000-3500 at about 240-260 load, retarding the timing doesnt take the knock away, I was told that I might have to add timing as too little timing will cause knock
Old Aug 16, 2008 | 05:04 PM
Mellon Racing's Avatar
sometimes that's true especially when you're hanging out in negative timing land
Hydroyo
Cobb AccessPORT
Jan 8, 2014 06:19 PM
Eisen7
Dec 21, 2012 03:47 PM
GTR2009
12
Jul 22, 2009 12:46 PM
acamus
Oct 24, 2008 06:22 AM
SophieSleeps
Nov 12, 2006 08:27 PM
