Autosmoothing tool for Fuel and Ignition Maps
Old Aug 21, 2008 | 01:17 PM
TouringBubble's Avatar
Nothing special ... I just changed the scaling to match mine and set the plateau and limits where I needed them in the fuel page. I suck at Excel man ... I wouldn't dare touch those formulas ... lol
Old Aug 21, 2008 | 01:29 PM
inco9nito99's Avatar
I'd be interesting to see if you can devise up a program similar to this for the MIVEC map.
Old Aug 21, 2008 | 01:48 PM
Inco, you can use the timing smoother for MIVEC as well ... the MIVEC map is 20W x 16H. Paste it in and then duplicate the last row and column (to avoid unwanted values from interpolating). Copy from the top map and paste in ...
Old Aug 21, 2008 | 02:06 PM
nonschlont's Avatar
oooohhh, Sweet! Gonna try that tonight!
Old Aug 21, 2008 | 02:33 PM
Jumperalex's Avatar
save yourself the effort ... I'll gin up a quick mivec version, no bell and whistles like the fuel smoother, but saves a lot of time. [gets to work]
Old Aug 21, 2008 | 02:57 PM
...waiting patiently, thanks Jumper!
Old Aug 21, 2008 | 03:14 PM
nonschlont's Avatar
Jumper...your da man! Thanx for sharing!
Old Aug 21, 2008 | 03:27 PM
Jumperalex's Avatar
actually I'll have a very nice surprise ... but first I need to know ... as the numbers in the mivec cells get larger what is that called? advanced or retarded?
Old Aug 21, 2008 | 03:35 PM
nonschlont's Avatar
my semi educated guess would be advance, but I would get a second on that! lol
we like surprises!
Old Aug 21, 2008 | 04:16 PM
Jumperalex's Avatar
ok and what is the practice limit to this advance? 30 degrees?
Old Aug 21, 2008 | 04:22 PM
Jumperalex's Avatar
and I assume no one goes for negative advance?
Old Aug 21, 2008 | 04:33 PM
Ph3n1x's Avatar
Great now im obsessed with smoothing maps. X(
Old Aug 21, 2008 | 05:07 PM
nonschlont's Avatar
sounds good. Im running 28.8's
Old Aug 21, 2008 | 05:09 PM
nonschlont's Avatar
I know this is freakin SWEET!
Old Aug 21, 2008 | 05:22 PM
mscorei's Avatar
on the mivec map the load numbers on the horizontal are a little bit confusing. should start as: 0, 10, 20 to 280 load, but they are : 10, 20, 30 to 300 load. just a little observation for improving your file! great work, man!
