Another idle problem with A/C on.
Old Aug 21, 2008 | 03:06 PM
joedr's Avatar
EvoM Moderator
Thumbs up Another idle problem with A/C on.
Hi all,
I am running into a situation that I have not been able to fix on my IX. It seems that I nailed down the idle with A/C off and on while the car is not running, but every other time my car stalls and shut off with the A/C while running.
Here is the scenario: When cruising 3000-5000 RPMs and I had to stop at a Stop sign or traffic light... once I press the clutch to place the car in neutral, the car will go stright to 0 RPMs shutting off the engine. On some other occassions, the engine from 3-5K RPMs will drop to 500 RPMs and bounced back to 1500 RPMS, go down to 700 RPMs and bounce back to 1100 RPMs and then stabilized to around 1000 RPMs (Target RPM).
Here are some details:
1. SAS mode - Car has 900 +/- 50 RPMs
2. I advanced the timing at idle to 10*.
3. No P0300 code is triggered.
4. Target dle, ISCV steps, etc as the picture below.
Any hints suggestins will be greatly appreciated!
Old Aug 21, 2008 | 03:38 PM
chrisw's Avatar
have you done a boost leak check? your throttle body shaft seals may be leaking, or the ISC is dirty or malfunctioning.
Old Aug 21, 2008 | 04:55 PM
joedr's Avatar
EvoM Moderator
i could not find any noticeable leaks!
I will check the ISC for carbon build up.
Old Aug 21, 2008 | 05:00 PM
wrceuro's Avatar
I have the same issues with my 2004 VIII. can someone please help us out.
Old Aug 22, 2008 | 06:44 AM
tephra's Avatar
mods?
what are your fuel trims like/
Old Aug 22, 2008 | 06:46 AM
KazzEvo8's Avatar
Who's intake are you running?
Old Aug 22, 2008 | 08:08 AM
joedr's Avatar
EvoM Moderator
Thumbs up
Mods are: Ported Head and valve job, Ported IM & Exhaust manifold, FPGreen, PTE780, BR TBE, BR UICP, Nisei LICP, BR Intake/Filter and GSC S2s.
All trims except O2 feedback are 0 +/- 1 with Mitsulogger.
AFRs at idle are 14.4-15.8 and 11.4-11.6 at WOT (Stable)
tephra,
Do you suggest to increase the idle engine speed using SAS to about 1000 RPMs?
Old Aug 22, 2008 | 08:21 AM
JohnBradley's Avatar
You can't use the SAS BISS screw setting since thats for stock cams. Adjust the BISS with the car running normally and not on the SAS mode until you get 1000rpm from it. We have had to do this on numerous cars including some stock cammed 03's. Its seeming to become a more common issue. Even my car is doing it. The other thing you can do is richen the idle a little (13.0-13.5) by letting it idle in open loop.
Old Aug 22, 2008 | 11:49 AM
joedr's Avatar
EvoM Moderator
JB,
The thing is that the car will idle very nice at 1000 RPMs while not running with A/C off and on. Even cruising with A/C off is no problem, it seems that the problem starts when the A/C is on while getting the car into neutral creates a sudden RPM drop to stall or shut off the engine. Very anoying. :-)
I will try to decrease the AFRs at idle to see if it improves the situation.
Old Aug 22, 2008 | 01:11 PM
joedr's Avatar
EvoM Moderator
Under the ISCV initial step fields.... What does higher the number means?
If I increase that number, the duty cycle inclease on the ISCV.... thus resulting in higher RPMs. Am I right on that assumption?
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
justboosted02
Aug 19, 2013 05:29 PM
btownsoccer22
Oct 21, 2011 10:31 PM
Darewood
Apr 20, 2011 03:26 AM
DrBump471
Jun 24, 2005 07:16 PM
