Car shuts off/ Bucks at 60% throttle 2100 RPMS 6 psi boost
Old Aug 27, 2008 | 10:28 PM
Turbo Kyle's Avatar
Here is the other part of the same log...looks like the front O2 goes to zero for a sec.
Old Aug 27, 2008 | 10:52 PM
JohnBradley's Avatar
my email is in my sig
Old Aug 28, 2008 | 12:09 AM
Turbo Kyle's Avatar
I tested the car cold...when its clod it wont buck...I tried it 3 times....no problems...and soon as it got warm it came back.
I also looked at the Boost Desired table...whats with the dip here? This is off my stock map. I have a MBC is this even relevent?
Old Aug 28, 2008 | 05:28 AM
TouringBubble's Avatar
What about the boost limit table?
You're correct. BDEL is irrelevant with an MBC.
Old Aug 28, 2008 | 08:08 AM
Turbo Kyle's Avatar
Old Aug 28, 2008 | 09:57 AM
cpoevo's Avatar
Does your car do it everytime?
Old Aug 28, 2008 | 10:09 AM
Turbo Kyle's Avatar
Everytime, unless the motor is cold in the morning.
Old Aug 28, 2008 | 02:57 PM
Turbo Kyle's Avatar
Bump
Old Aug 31, 2008 | 01:23 PM
IDRINKV8's Avatar
whats your load value set at?
Old Aug 31, 2008 | 04:17 PM
Turbo Kyle's Avatar
Sorry, I fixed it. I had the lean spool messed up. My ECU did like when I set the start/stop to 2500. Aaron fixed it for me by turning of lean spool in the XML area. The car is fine now....other than that fact I have to retune the whole car.
Old Sep 1, 2008 | 07:00 PM
Well it wasnt just what it was set at, it was also the ROM def that was changed. We got it though thats all that matters.
Old Sep 1, 2008 | 07:04 PM
Turbo Kyle's Avatar
^ My ninja!
Get back to me about the injectors!
Old Sep 2, 2008 | 02:52 AM
SoCalRedLine's Avatar
I had this problem once, (after a few tests) it was related to the open loop transition at that RPM. I just lowered the load at that RPM cell and it transitioned from closed to open without the hiccup.
...i also stopped logging from <2500rpm
edit: i also had a similar problem when messing with the boost-enhancement/lean spool tables.
