Boost Desired Engine Load?
Old Aug 28, 2008 | 12:19 AM
Turbo Kyle's Avatar
Exclamation Boost Desired Engine Load?
What does it do....and is it relevent if I have a MBC?
This is my stock one...Im having a bucking issue between 1800 and 2300 RPMS at the 120-135 load area
Whats with the dip?
Old Aug 28, 2008 | 12:37 AM
tephra's Avatar
If you have disconnected your stock BCS then no the BDEL table has no impact.
Post up your boost limit table please!
Old Aug 28, 2008 | 01:07 AM
RazorLab's Avatar
With MBC it means nothing.
Boost Limit table however does and it goes by load #
Do not disconnect (electrical connection) the stock BCS or you will get a CEL
Old Aug 28, 2008 | 01:55 AM
tephra's Avatar
^ sorry when I said disconnected i didn't mean electricals I meant vacuum hoses
Old Aug 28, 2008 | 08:07 AM
Turbo Kyle's Avatar
Old Aug 28, 2008 | 10:22 AM
RazorLab's Avatar
Yea I knew what you meant but others might not, that is why I specified the electrical connection.
Old Aug 28, 2008 | 10:47 AM
TouringBubble's Avatar
It wouldn't hurt to smooth out that dip I guess ... perhaps there is some connection between the BDEL map and fuel cut that we aren't aware of ... Try:
2500 > 150
2750 > 146
3000 > 143
Just to see ...
Old Aug 28, 2008 | 12:11 PM
todd6027's Avatar
might be the fuel pump change over from low to high voltage or maybe the lack of ,,check fuel pump relays or hardwire the pump see if it goes away
Old Aug 28, 2008 | 12:18 PM
Turbo Kyle's Avatar
Whis I had a Fuel pressure guage...LOL
I didnt know there were 2 fuel pump relays.
4b11slayer
Aug 1, 2017 07:59 PM
jb988
May 2, 2016 05:35 PM
leecavturbo
Feb 14, 2009 02:04 PM
Profoxcg
Feb 9, 2008 06:24 PM
truDriver
Apr 21, 2007 09:44 AM
