help with 1000cc injectors
Old Sep 6, 2008 | 08:45 AM
mfr122887's Avatar
Originally Posted by JohnBradley
1000's on gas should be in the 800's and the latencies should be in the .900 range or so. Look at Injector Rehab for the latency list for some starting points. Then follow the trims very close.
As far as the latencies, are you referring to the 11.7v or the 14v?
I am still having trouble with this, I tried a few more combinations and the idle trim will always be fine, around -3. Cruise will look good after like 10-15 minutes at -4 then I will check it a few days later after some driving and it will be at -12. Any help?
Old Sep 8, 2008 | 08:26 PM
mfr122887's Avatar
Bump
Old Sep 8, 2008 | 08:41 PM
JohnBradley's Avatar
11.7- would be in the .930-.960 range
14v- would be in .700 range
Injector Rehab has alot of good starting points for these. Remember you need to alter all the values that it wont even see in normal operation sometimes. Other things that can affect the trims are intake systems with incorrect design or cone filters that alter the KV readings in the MAF. Then you have combos of both sometimes playing games with you.
socalx_dsm
Apr 11, 2017 01:16 PM
dmotors
Jan 17, 2016 02:30 PM
tzoyi
Feb 20, 2012 10:31 AM
s.e.a.n.
11
Aug 10, 2010 07:19 AM
