Logging LC-1 with EVOScan? - help
Old Aug 31, 2008 | 04:18 PM
Turbo Kyle's Avatar
Originally Posted by Jorge T
Never, Never pull the serial plug out of the LC1 when its powered up. It will loose calibration since you're shorting out the the connection when the plug is pulled out.
My LC1 works fine with evoscan 2.5, make sure that LC-1 (Direct Innovate serial protocol 2) is checked too (see wideband on the top menu)
So should you also have the serial port plugged in before you power up the WB?
Old Aug 31, 2008 | 04:26 PM
Jorge T's Avatar
Make all connections to LC1 with engine off. Laptop ends being a ground too...
Old Aug 31, 2008 | 04:44 PM
Turbo Kyle's Avatar
Thanks Amigo!
Old Aug 31, 2008 | 06:12 PM
nothere's Avatar
/ lc-1?
I think the laptop side of the plug can be disconnected any time. Its prolly best to leave the cable in the lc-1 all the time. Why take it out?
Old Aug 31, 2008 | 07:19 PM
Turbo Kyle's Avatar
I found out my problem, I did have the Terminator plug in the "IN" plug on the LC1. Now my readings are all crazy. Looks like Ill have to recalibrate everything.
Old Aug 31, 2008 | 08:36 PM
evo8dad's Avatar
I'm glad you solved your issue Kyle but, I'm still have problems. I can log the LC-1 fine through LogWorks and Mitsulogger but, this damn EVOScan keeps showing me numbers from 5.xxx to 3.xxx???
I've tried PMing mad4evo and even sent an inquiry through his site but, haven't gotten a response (its been 5 days now!!).
Old Aug 31, 2008 | 08:40 PM
nothere's Avatar
, make sure that LC-1 (Direct Innovate serial protocol 2) is checked too (see wideband on the top menu)[/QUOTE]
Old Aug 31, 2008 | 08:45 PM
Turbo Kyle's Avatar
More problems here...this is what I posted on innovates forum>
I have a newer LC1 with the Blue DB gauge. I have the KeySpan USB/serial converter. When I hook up the serial cable, I plug it onto the "OUT" on the LC1, put the terminator in the "IN". When I hook up the serial cable to my laptop the LC1 seems to get messed up. I power it up and start the car and the DB guage goes to 15 and flases the red LED. When I disconect the serial port and try to power up the car again the DB guage acts like it warmming up then get to 15 or so and flashes. The only way I can get it to work is pull the O2 disconnect it from the LC1. Do the heater calibration and the Free air then the DB guage starts to work. If I plug in the serial connector it freaks out again. Any Ideas? Its a pain the the rear to keep pulling the O2
Old Sep 2, 2008 | 07:12 AM
evo8dad's Avatar
Huh, thats a little different than my issue. I can log the LC-1 fine in both LogWorks and Mitsulogger, its just this darn EvoScan and I can't seem to get any help from them (mad4evo, EvoScan)? My issues continue....
Old Sep 2, 2008 | 09:48 AM
Turbo Kyle's Avatar
I pulled the LC1 Im getting something else
Old Sep 5, 2008 | 07:15 PM
partyboy1122's Avatar
I have my LC-1 hooked up and it still will not read with evoscan?
The AFRMAP section has some readings, but as Jorge T said it's not the correct one?
Nothing under the WIDEBAND COLUMN logs........any ideas, common problems?
Old Sep 5, 2008 | 07:19 PM
nothere's Avatar
you are selecting the WB type at the top of the page?
Old Sep 5, 2008 | 07:21 PM
Yes, it's selected along with the comp port. It logs fine on Logworks tho....
Old Sep 5, 2008 | 11:49 PM
PeteyTurbo's Avatar
Did you make sure that the LC1 did not utilize a custom output multiplier? Use the LM programmer to check..
Old Sep 6, 2008 | 09:44 AM
EatSleepBoost's Avatar
is there a step by step thread on here somewhere about how to log a LC 1 with evoscan. my wideband is installed and i know i have to go get the serial to usb adapter. i also know u have to put the terminator plug in (i don't know if it goes in in out or the in). what do u do next. select external wb on evoscan or wat are the other steps
