88590015 Evo Live Map - ROM and software
Old Dec 1, 2009 | 01:52 PM
  #76
jcsbanks's Avatar
https://www.evolutionm.net/forums/ec...ode-works.html
Above is a summary of the latest version of the code.
Old Dec 1, 2009 | 02:10 PM
  #77
R/TErnie's Avatar
thanks john and mychailo
Old Dec 1, 2009 | 02:53 PM
  #78
logic's Avatar
Also, FYI: I checked a copy of the last assembly version of the source John posted into the SVN repository, under the "asm" directory. (Hint, hint to anyone else who has commented source code for patches that they'd like to contribute...)
Old Dec 1, 2009 | 03:16 PM
  #79
SoCalRedLine's Avatar
Originally Posted by jscbanks
Sadly between running a medical practice and working on the GTR for Cobb I have less than zero time to dig it all out again, but I hope something can be done with it.
I'm sorry to say as well it took six months after I posted this for anyone to test it, by then things move on and I forget what I've done. I just can't work like that, I need something tested that week otherwise I just can't bring it all back.
Damn, ur a busy guy...just wish I was smart enough to figure out how to get negative time, I'd go back and test this when u put it out ...lol. This thread flew completely under my radar, as I thought only the 9653- rom could do live tuning. Now I kno that it was just cause more people own viii's.
If someone could donate me a full version of the assembly program, along with the definition for the sh7052 processor, I co
Old Dec 11, 2009 | 03:38 PM
  #80
ziad's Avatar
ok i think i have it all sorted, so if someone wants to test it can they pm me their email address i will send them a rom and xml.
Old Dec 15, 2009 | 01:20 PM
  #81
I have been busy with finals, but ill test it out. Email me here:
socalredline@gmail.com
p.s. Thanks for taking the time to do this, mate!
Old Dec 15, 2009 | 03:41 PM
  #82
ziad's Avatar
i got temporary bad news.... something is not right. anyway seeing i didnt get a response for a cpl days i was able to use a E9 ecu conncted to my car and yeah can log via normal mut in mitsuloger.... but mut via my program didnt work and dma via my program didnt work.... not sure of the reason. need more time but been busy for the last days working with 15year old computers running winme and accoouning program not running properly under winxp and tuning my car wiith e85
i will get back in a few days, this time i will pm u directly
Old Jan 9, 2010 | 08:20 PM
  #83
dvant.nz's Avatar
link to file
I cannot seem to find release88590015.zip anywhere.
Anyone got a copy hiding?
Ta
Old Jan 29, 2010 | 11:48 PM
  #84
SyZyGy1394's Avatar
^this.
Old Jan 30, 2010 | 03:17 PM
  #85
ziad's Avatar
i noticed that too. looks like JB's original server is down.
u can download from here, obviously it only works on tephraV5.10, i will put up a copy on the evo wiki.
http://www.mztec.org/evo/roms/Release88590015.zip
Old Aug 24, 2010 | 09:38 AM
  #86
rgar's Avatar
Any updates on this. I would love to get a version for V7.
Old Aug 24, 2010 | 09:44 AM
  #87
SyZyGy1394's Avatar
Tell me about it....
Old May 17, 2011 | 04:11 PM
  #88
Dochka's Avatar
Originally Posted by jcsbanks
88590015 Realtime/DMA logging/Tephra 5.10 test
Use your Tephra 5.10 xml, flash the attached ROM.
http://banks.myzen.co.uk/Release88590015.zip UPDATED with 1 byte load on Request ID 00 to allow knock/map tracing, new PC application.
Then run the attached Evo Live Map PC application and click start to begin datalogging.
You are logging the first 64 items of your ECU's MUT table at much higher rates than normal MUT logging. The definitions are reconfigurable. In the right hand window you will see the address of the MUT table configured for 88590015. I've tested all this by flashing the 88590015 ROM to my JDM ECU and it works. You can make your own MUT table in ROM if you wish and change the baud rate in the ECU. I've tested logging up to 25 times MUT.
Whilst logging, you can also rewrite the alt maps in realtime. Find your map using the choose ECU ROM file and then after you make changes to alt maps in Ecuflash hit ctrl-s to save, then (whilst still logging) hit write in Evo Live Map.
Try confirming that you can change the fuel map by altering the 14.7 AFR cells with the engine off to say 15.2, then see that AFRmap in the logs is changed from 128 - you can do this with the engine off. You need to be alt maps to see the changes.
Build up and test slowly - first engine off, then at idle, test for no knock and sensible AFR on your first WOT to make sure nothing funny is going on.
I've tested what I can, but without a US Evo IX I can do no more before putting this out to test.
Please can you post another download link, I can't download anything from dns or myzen;
Thanks
Old May 17, 2011 | 05:05 PM
  #89
eXtreme-Speed's Avatar
Go to the Tephra V7 Thread for download.
Old May 19, 2011 | 07:20 AM
  #90
SyZyGy1394's Avatar
Is that a joke? The Tephra v7 and Live Map rom have never been posted for 88590015 as far as I know, otherwise I'd be all over that ish like hot cakes.
