My car was un-tuned
Old Sep 8, 2008 | 06:17 PM
RyeLou's Avatar
My car was un-tuned
Without naming names, here is my issue.
I bought my car with a few mods, AMS did the original tune. Things were fine. I installed cams and a LICP and took it somewhere that I thought was reputable to get tuned. I've had a few small problems since, but nothing major. They actually started on the dyno, but I figured I would get them sorted out afterwords. Long story short, I got a tactirx cable and hooked it up today. My tune is almost identical to an '05 stock .hex file.
My question is is there any chance my tune could come out to this close to what a stock tune would look like? And if not, has any damage been done in the past 3 weeks of driving it? I know normal driving wouldn't hurt too much, but accelerating to redline wouldn't be good I would imagine..
Old Sep 8, 2008 | 06:28 PM
burgers22's Avatar
The stock tune is pretty conservative, so if you have retained the stock air box it is unlikly your car has suffered any damage, best to get the AFRs checked with a wideband and do some runs to log any knock.
MB
Old Sep 8, 2008 | 06:42 PM
RyeLou's Avatar
I don't have the stock airbox. I did just do a few runs and logged knock. Seems I'm only hitting 1 random one from time to time...so the tune seems to be right? I can't believe it would be so close to a stock tune. Something doesn't seem right. The only thing that has changed is low octane fuel map, that's it.
Old Sep 8, 2008 | 06:46 PM
vmrevo9's Avatar
Veteran: Air Force
check with a Wideband to make sure that the AFR's are ok
Old Sep 8, 2008 | 06:49 PM
JRB_EVO's Avatar
Humm, that doesn't make any sense.
Take it to another place to get tuned, specially since you have cams, usually these will cause the tune to have to run a couple of degrees less of timing up top, at least that's what I have seen for the most part.
Old Sep 8, 2008 | 06:53 PM
Evoryder's Avatar
Only thing you've done is waste fuel/power. What was the boost set to? I'd like to see what your fuel / timing maps look like.
Also, without naming names "Payne Tune" ...who are they? Guess that's a good name for a tuning company that doesn't tune lol
Old Sep 8, 2008 | 07:19 PM
RyeLou's Avatar
Didn't think about that part...oops. There was a wideband used on the dyno. I would have to hope that through this apparent cluster **** he would have at least paid attention to that if nothing else.
Boost is set to about 22/23. Here are my maps. Left side is from the stock 96940011 file and the right side is what I pulled off my car.
Old Sep 8, 2008 | 07:26 PM
warp9's Avatar
The reload maps appear way leaner. I would contact Mellon and he will get you on the right track.
JRB_EVO's Avatar
There are some slight differences, I'm no expert but probably you could have a better tune. Hopeffuly you can now get a better tune and enjoy the car even more!!!
Old Sep 8, 2008 | 07:29 PM
Evoryder's Avatar
If they are a vendor on the site you might want to take the screen shot down. For future reference pm someone if they are asking for information like that.
It is clearly different, nothing significant but it's still been modified. Pm me the .hex file's of before and after I wanna see how rough it is in graph format.
Old Sep 8, 2008 | 07:30 PM
RyeLou's Avatar
Evoryder's Avatar
Way leaner? where? The area of 10.xx?
Old Sep 8, 2008 | 07:31 PM
RyeLou's Avatar
It's not a vendor. I am familiar with the rules though. I'm going to take them down in a bit. I'll PM you what I have. I don't have a "before" though. I have a "stock" and a "now".
Old Sep 8, 2008 | 07:32 PM
warp9's Avatar
Yes sir
Old Sep 8, 2008 | 07:34 PM
tephra's Avatar
All looks ok to me.
I mean it probably needs a bit of work - but I wouldn't say its a terrible tune...
