Low load timing not matching your maps?
Old Apr 17, 2009 | 06:22 PM
  #76
Jack_of_Trades's Avatar
So...if we want to know what our stock base timing would roughly be with this FAA bit11 disabled, we can take a look at a JDM timing map? What rom ID is from a JDM (non-EGR) evo?
Old Apr 17, 2009 | 06:53 PM
  #77
tephra's Avatar
leaving this bit enabled (it comes enabled) basically drops between 3* and 8* of timing when under 3500rpm, low load areas.
disabling this bit stops this reduction in timing.
I suggest b4 disabling it, get a good baseline log of low load timing + knock. THEN disable the bit and then relog - if you get more knock then you will need to reduce the timing a little...
Old Aug 30, 2009 | 09:19 PM
  #78
fixem2's Avatar
Anyone still running with FAA Bit10 disabled?
Old Aug 31, 2009 | 02:50 AM
  #79
madvally's Avatar
Yes!
Did this mod about 2 months ago.
Everything still running smoothly. Just drop you timing in the low load areas by about 3 degrees before you disable the bit - just in case!
This mod makes your car's daily driving characteristics more consistent.
Go for it, you wont be sorry!
Old Aug 31, 2009 | 03:14 AM
  #80
tephra's Avatar
yeh i never had a problem with it.
as per above, just drop your low load igntion prior to doing it, then ramp it back up after logging/checking for knock
Old Nov 11, 2009 | 12:46 PM
  #81
Boosted GP's Avatar
Hi Guys,
I have tephra v7 + mods on my car (ony got round to it today) and doing some logs it seems to be ADDING timing above the 90 load... i haven't gone above 200 load yet but from 90 -200 it will add anything from 2-5 deg more advance compared to my timing map and its not consistant with the add either... any thoughts?
thankfully my car is not tuned yet so i have conservative timing (dont want to go over mbt on e85) so no knock.
Mike
Old Nov 15, 2009 | 09:49 AM
  #82
todd6027's Avatar
90550001 /98640014 evo7 or any 5/6 rom
tephra
Apr 22, 2026 11:03 AM
chmodlf
Aug 31, 2018 01:38 PM
jcsbanks
Jun 9, 2011 11:45 AM
Seijuro
Mar 20, 2010 11:53 AM
jfitzpat
Jan 17, 2007 09:32 PM
