Problems with stationary rev limiter
Old Sep 29, 2008 | 05:52 AM
MR Turco's Avatar
Does anyone else have the problem where the stationary rev limiter (2-step) will randomly just not work? Mine does, i.e the other night i was trying to be a ricer in the parking lot at a local meet and the revs just kept climbing. I wasn't on a level surface but the car was not rolling. Clutch was in. I even tried it with the ebrake engaged.
This is not the first time it has happened. I know another local guy mentioned it has flaked on him before too.
Old Sep 29, 2008 | 09:09 AM
dudical26's Avatar
the 2-step seems to have a bunch of condition that you need to meet in order to get it to work.
I have found that if you push the clutch in while you are still rolling it wont work. Even if you come to a complete stop after. My 2-step used to dissapear every once in a while untill I figured this out. Basically just be very methodical about using it. Come to a complete stop, push the clutch in and put the car in neutral, let the clutch out. Then clutch in again and go into gear. Thats what I do now and it always works.
Old Sep 29, 2008 | 10:00 AM
MR Turco's Avatar
Thanks for the help.
Old Sep 29, 2008 | 10:03 AM
shangai's Avatar
did you check that the pedal is always touching the switch?
Old Sep 29, 2008 | 10:05 AM
MR Turco's Avatar
I havent checked but i cant start the car without it so i assume it is always hitting.
Old Sep 29, 2008 | 12:38 PM
dudical26's Avatar
Try what I said from now on and I don't think you'll ever have the problem again.
Old Sep 29, 2008 | 01:33 PM
hellcat's Avatar
There is a "no acting like a ricer" condition that must be met before the 2step will engage properly..lol jk I have had this happen to me a few times. I think it happens because my car is rolling slightly. Maybe the parking lot you were in was on an incline?
Old Sep 29, 2008 | 03:48 PM
silver_evo's Avatar
For me, my logged speed (the speed MUT ID) has to be 0.00 for it to work. Havent really played with it much.
