Tuning Cam Idle
Old Oct 6, 2008 | 01:42 AM
RoadSpike's Avatar
Tuning Cam Idle
So.. apparently there is some conflicting information out here about the "best" way of tuning up the idle on cams. Right now I'm trying to compile a list of settings that should be tweaked.
I'll go over what i've done and if it helped or not.
1) Changed the timing to 11* at idle (well that sucked and threw the p300 code so i took it back out)
2) Enabled SAS mode and adjusted the idle screw a little until the idle was around 800 rpm, the idle was still hunting but after disabling the SAS mode it was MUCH better.
3) Played around with the desired ISCV tables. It "appears" to help especially for the AC mode but the idle is still hunting.
Currently the car is very drivable fuel trims are solid, even the ISCV steps appear to be semi stable but the AFR is always hunting like crazy and my vacuum at idle is also hunting in correlation with the AFR.
So I'm assuming at this point the ISCV steps as logged by evo scan really doesn't correspond with the real ISCV point in time. I'm guessing its some kind of "target" that its trying to reach. Also while I'm at it the MAF HZ seem to be very stable they aren't bouncing around sometimes i get 47hz when the idle speed surges a little.
I'm running with S1 cams which aren't very aggressive. I was expecting these to idle near stock but they wont :P. If you guys have any experience messing with the cams please give me some tips for doing so.
Old Oct 6, 2008 | 07:40 AM
JohnBradley's Avatar
It should only require 8-9* of idle advance, set the desired idle in neutral to 950 or so, bump the ISC for AC off/neutral a little and it should be good. You may need to adjust the BISS with the SAS function off since its not really designed for use with cams. Set it by ear and you'll know what I mean.
Old Oct 6, 2008 | 09:10 AM
RoadSpike's Avatar
I set the timing back to 7* which i know is already slightly higher than the stock 5*. Still got some basic questions for you though.
When setting the BISS is the idle supposed to be steady?
And will bumping up the desired ISCV stop this idle and AFR ranging that i see?
Also since i'm in cali I'm not sure i can set the idle that high or not to pass emissions
Old Oct 6, 2008 | 09:13 AM
Wicked E's Avatar
Might be time to hit up RazorLab at GST...
-E
Old Oct 6, 2008 | 09:22 AM
RoadSpike's Avatar
-E
No offense but i want to learn how it works not have it done
Old Oct 6, 2008 | 09:29 AM
Wicked E's Avatar
I take great offense to that...
Good on you for wanting to learn on your own...
-E
Old Oct 6, 2008 | 11:28 AM
yeah set the BISS correctly and it wont hunt it will be set at the desired idle. Most emissions testing require the idle be below 1100 I think...1000 to be safe and you should have it.
Old Oct 6, 2008 | 11:49 AM
RazorLab's Avatar
That buschur metal induction pipe is a serious pita to tune at idle. I would follow everything JB has suggested and see how it takes it.
Other thing to check is the ISC gear. I've seen some 03-04 have the little plastic gears cracked or broken and no matter what you try you will never get the thing to idle because it physically can't.
Old Oct 6, 2008 | 11:55 AM
meckert's Avatar
Sounds like you need to figure out what your cam timing is on the intake an exh. Sounds like Lobe centers are very close causing your choppy idle. If you have adj cam gears you need to retard them...there have been multiple threads on retarding cam timing to get better idle... Just a thought.
Old Oct 6, 2008 | 07:16 PM
RoadSpike's Avatar
Update:
Well I adjusted the BISS until i was hovering somewhere around 900rpm or so and then turned up the ISCV a couple points above stock in the last two columns. The idle is definitely much improved.
I think I could be battling an issue with missfire too, one of my plug wires appears to be damaged so I've ordered up a set. Cams are fun though definitely has opened up the power band above that 5500 rpm mark.
Old Oct 6, 2008 | 07:27 PM
vvhiteix's Avatar
yea i have been having a little trouble as well... my a/f still hunts around like you were saying...idle drops when i clutch in occasionally... but it has to do with the ics values just havent gotten around to raising them... also i have the okada packs now... that seemed to help actually.
Old Oct 7, 2008 | 04:31 PM
ciobing's Avatar
What is the BISS? How can I adjust the Biss with the SAS?
Old Oct 7, 2008 | 05:01 PM
ciobing's Avatar
to retarde the exhaust cam to get worse idle,or intake is more influential?
Old Oct 7, 2008 | 05:33 PM
Pd1's Avatar
Pd1
Retarding the intake cam will help with idle. Leave the exhaust at 0 or -1.
Old Oct 8, 2008 | 03:53 AM
ciobing's Avatar
ok about the intake,but if I delay the exhauste from 0 to -1(the overlap increment) the idle worsens?
