switch ROM ID's...
Old Oct 8, 2008 | 01:42 PM
EvoIXMR's Avatar
Tyring to work with 94170015 so I can replace my 96420007 map....
1) I switched the CHANGEME to big as I have ecuflash 1.35
2) I copied over the XML stuff and then tried to open the 015 file in evoscan...
Issues I am having:
1) Under Misc section, for Wastegate Compensation, I get the following error:
"The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again"
2) Also, the map title is in light gret and so are some other maps like Init Code and Boost Enhancement Table as well as several others...
3) Also, I See that Tephra suggests to remove Boost Desired Engine Load #2 and #3, only #1 matters anymore, but I have #1, #2, #3 and #4...should I remove #4 as well...
<table name="Boost Desired Engine Load # 1" address="44f8">
<table name="RPM" address="6982" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2" address="450e">
</table>
<table name="Boost Desired Engine Load # 3" address="4524">
</table>
<table name="Boost Desired Engine Load # 4" address="453a">
</table>
4) Remove/Rename your current "Base Wastegate Duty" #2 and #3, only #1 matters anymore - My 015 map does not have #1, #2 or #3
I am n00b to this, so I could be doing something wrong!
Thanks
Old Oct 17, 2008 | 04:27 PM
8UpUrV8's Avatar
In regards to changing the 008 xml file to 14/15
Originally Posted by Appauldd
That is pretty much all it takes. You can't copy and paste like normal though. You have to open the given date field then click edit then select all then click copy. Then you have to open the 15 rom same data field and repeat the click edit but then click paste. You will see it all maps over pretty easily.
I hope this helps.
Paul
I want to upgrade to a 94170014 stock rom (I have a 94170008), I know where and how to edit both xml files, but what and where do things get moved around?
I.E.- copy inside 008, press ctrl+A inside of 14, and hit paste? or Vice-versa??
Thanks!
Old Mar 30, 2009 | 06:43 PM
VRSF Tiago's Avatar
Issues I am having:
</table>
</table>
</table>
</table>
Thanks
Were you ever able to get your 96420007 replaced with 94170015?
