fed up with knock control
Old Oct 31, 2008 | 05:44 AM
  #166
supersal's Avatar
Waiting pateintly for 88840016...
Keep up the Good Work!!!
Old Oct 31, 2008 | 06:24 AM
  #167
travman's Avatar
Originally Posted by tephra
I will be testing this more thouroughly (sp!!!) on my car this week/end.
Once I have verified that it does what its meant to then I will release a few ROMID's and let the general population give feedback...
96530006 will be one, what other ROMID for ppl with phantom knock? and dont ask for 96940011
Is this coming out for 88590015?
Old Oct 31, 2008 | 06:38 AM
  #168
DCsleeper's Avatar
Here is another vote for 94170015.
Old Oct 31, 2008 | 06:57 AM
  #169
mfr122887's Avatar
Tephra - Will the Knock CEL mod blink according to the original knock sum or the modified knock sum?
Old Oct 31, 2008 | 07:00 AM
  #170
tephra's Avatar
original KS...
Old Oct 31, 2008 | 07:05 AM
  #171
todd6027's Avatar
90550001 ?? please.
Old Oct 31, 2008 | 07:22 AM
  #172
dudical26's Avatar
Another vote for 88590015 PLEASE.
Old Oct 31, 2008 | 11:40 AM
  #173
D-VO's Avatar
Hey Tephra I have to ask why we should not to ask for 96940011. Is it because you've been getting a lot of requests for it? Or, is it because it's a difficult one? Should I just give up hope?
Old Oct 31, 2008 | 12:09 PM
  #174
justboosted02's Avatar
im pretty sure there is no room in that rom for the patch im also pretty sure there is another rom you can switch to with little negative side effects
Old Oct 31, 2008 | 12:19 PM
  #175
Rob_GPT's Avatar
Just to add to the weird harmonics theory. Right before I spun the #1 bearing i would get ticking in the 3500 RPM range +- 500 ish. There is something going on in that range for sure.
I'm right in the middle of a 2.3 build. Hope i get lucky and don't have a bunch of phantom knock.
Old Nov 1, 2008 | 10:10 PM
  #176
D-VO's Avatar
When do I actually run out of space on this ECU? It looks like I have about 290 lines in use right now. I don't mind switching to another rom, I just don't want to loose my immobilizer. I can also delete some mods I'm not using to make space if I have to. I'd rather have this knock mod in place of some other mods.
Old Nov 2, 2008 | 06:12 AM
  #177
Ph3n1x's Avatar
Ok so I have some good news. I have a customer that had the intermittent 30 count knock on spool up (stock turbo). Couldn't solve it for nothing. Well he went ahead and changed two things. One being replaced his catback with the stock exhaust and put a QTP downpipe cutout. Second being he replaced his Timing belt and associated parts.
Now, No knock.
So its interesting to see, I personally think a faulty tensioner may be causing noise that fools the knock sensor, or it could have been a loose exhaust. Who knows.
Just my findings.
Old Nov 2, 2008 | 06:24 AM
  #178
Mellon Racing's Avatar
good info and I bet you guys are so freaking happy that it's fixed!
Old Nov 2, 2008 | 06:29 AM
  #179
Ph3n1x's Avatar
Yeah now If i could figure out whats causing mine, lol
Old Nov 2, 2008 | 07:24 AM
  #180
D-VO's Avatar
Now, No knock.
Just my findings.
I had a 36 knock count issue before my engine blew up the second time(really really blown head gasket). I re-used both tensioners but tightened the pulley tensioner a little more, removed the balance shafts, installed brand new set of spark plugs, changed the 3" downpipe to the one specified for the EVO 9 (ACD in the 05's)+(no flexpipe for the E9 dp), and changed to a Greddy 1.6mm headgasket. No more 36 count. I know I know, this isn't a definitive answer but, I could be any one of these things.
