higher boost/lower timing - how far is too far?
Old Oct 26, 2008 | 04:14 PM
EVO8LTW's Avatar
Originally Posted by razorlab
1bar boost? Peak and held? That has to be one slow evo...
Yeah...that's 15 psi gauge pressure, right?
Old Oct 26, 2008 | 04:43 PM
Jack_of_Trades's Avatar
Yeah, not even 15 psi lol.
Old Oct 26, 2008 | 04:44 PM
Oracle1's Avatar
That was my economy setting on my 2 stage map But because of the high timing in the low load it actually drove well, quicker than standard fq360.
Old Oct 26, 2008 | 04:46 PM
We should have Razorlab dyno tune a car at wastegate pressure with insane timing,lol.
Old Oct 26, 2008 | 05:20 PM
EVO8LTW's Avatar
My first "mail-in" tune from 2004 might fit the bill. 9 degrees at peak torque with about 22-23 degrees up top. The car didn't like more than 19 psi on pump gas.
Old Oct 26, 2008 | 07:22 PM
RazorLab's Avatar
I did 9 yesterday on E85 at 28psi and then at 19.5 psi as we are trying something out.
If I recall correctly it lost about 60wtq peak and an insane amount of area under the curve, the horsepower almost came together way way way way way up top at 7600 (stock turbo), and that was with me adding in timing on the 19.5psi map as well.
From what I have seen on the dyno, Boost will always give you more torque then timing will on our (stock compression) motor. Same thing up top unless it's a turbo that has gone beyond it's efficiency.
Old Oct 26, 2008 | 08:31 PM
tephra's Avatar
yeah thats always been my understanding.
Anyone got a compressor map for the IX turbo (not the RS one either :P)
Old Oct 27, 2008 | 08:35 PM
R/TErnie's Avatar
I ran 28psi at peak torque w/6 degrees of timing @ the 300% load cell... and 20psi at 7k with 10 degrees of timing.
on 92 octane. I made 350lb-ft/ 330awhp on a Dynojet. MIND YOU... It's October in the PNW... and its like 50 degrees outside at the warmest.
My car only runs into knock @ higher rpm's...the timing advance from the increase in RPM is very little. As you can see...there isn't much timing advance to be had. I've backed the timing off to remove all knock... the car works well.
Just a side note... race gas fixes all your problems.
Old Oct 27, 2008 | 08:39 PM
Erik@MIL.SPEC's Avatar
From all the people I have seen testing the Evo, including Razorlab and Aby, the Evo prefers more boost compared to more timing when you're looking for horsepower.
Old Oct 27, 2008 | 09:07 PM
03whitegsr's Avatar
It's more turbo size then anything. If you are pushing the airflow limits of the turbo, you are probably better off backing off the boost and running a little more timing advance. You'll only give up a small amount of power, but the car will feel a lot better under power.
If you have a ton of airflow available, it's surprising how high you can get the boost and drop the timing and never have an issue. Also, higher boost pressures NEED less timing advance anyway, so even if you have to drop the timing, you might still be right where the motor wants to be almost regardless of fuel quality.
Old Oct 28, 2008 | 03:50 AM
EVO8LTW's Avatar
So, there isn't such a thing as "dangerously low timing"? For example, if you were running 30 psi and 8 degrees up top (not what I'm doing, BTW), that wouldn't be a problem if the car ran well and made more power than lower boost/higher timing? Are there EGT issues to consider?
Speaking of low timing/high boost, did you guys catch Mellon's 10.5@138 g-tech video on pump gas/stock ECU? 35 psi...
Old Oct 28, 2008 | 07:06 AM
honki24's Avatar
Yes, there is a "dangerously low" timing value. Especially when modifying the valve timing (cam gears / Mivec). If you get under 3 degrees and you track the car you will melt stuff. Ask me how I know. I ran 25psi at Summit and VIR and finally at CMP it gave up on me. I melted the TURBINE BLADES. INCONEL! Now... the turbine melted only after the gasket melted (which introduced more air in the exhaust, which means I had a flamethrower) but still... too low timing increases EGT... especially if you see knock and then you get pulled down to 0 degrees or negative timing... Turbo won't last long that way. I was even running water injection. I don't go below 6 now.
Old Oct 28, 2008 | 07:27 AM
EVO8LTW's Avatar
You don't go below 6 degrees at any rpm range?
Old Oct 28, 2008 | 08:29 AM
matt55's Avatar
2*@ peak/12* up top
11.3 A/F
25-26psi
93 Octane
I dont think even at 23 psi I could run 6*@peak
Old Oct 28, 2008 | 09:31 AM
3*@peak/10*up top
11.5:1AFR
23psi@peak and holds to 7500rpm
93 octane
4*@peak/14* up top
11.5:1AFR
29psi@peak/23psi@7500rpm
73% 93 octane/27% meth mix with alky kit
