higher boost/lower timing - how far is too far?
Old Oct 30, 2008 | 10:38 AM
  #76
Vivid Racing's Avatar
^^^ Sounds about right for the street/drag (depending on the amount of injection of course) If road racing add some more fuel "for more cooling" say 11.0-11.3, it will loose power but at least you will be safe.
Evan Smith
Old Oct 30, 2008 | 11:14 AM
  #77
Nurburgring's Avatar
Very informative post, thanks everyone involved for sharing their insight!
Old Oct 30, 2008 | 11:22 AM
  #78
JohnBradley's Avatar
Originally Posted by VividRacing.com
Perfect
See Razorlab...
Forums can be respectful and not always a pissing match (JK)
Evan Smith
Bryan knows that my Irish temper is lurking in the shadows is all
Old Oct 30, 2008 | 12:36 PM
  #79
RazorLab's Avatar
hahah
Old Feb 11, 2009 | 07:25 AM
  #80
cij911's Avatar
Wow, very insightful postings....I am running 100% meth now with 91 (factory 9 turbo) and would LOVE to try adding H20, the question I have is what is the best process? If my current tune is knock free, 28 psi tapering to 21psi, AFRs ~10.8 - 11.3, timing 4* peak to 15* redline, should I :
(1) Just add 50% H20 (distilled) and log
(2) Add 50% H20 and change boost and timing (if so, which and by how much) and log
(3) Add 50% H20 and change boost, timing, and AFR (if so, which and by how much) and log
Thanks!
Old Feb 11, 2009 | 08:15 AM
  #81
honki24's Avatar
I've now logged about 30 roadcourse hours on a 37,000mi motor in my '03 running 24ishpsi on a stock turbo and 11:1 AFR, 4 deg min. timing, windshield wiper fluid injection (~40% meth, 378cc/min). I can safely say that this combo works. To be honest, I could really do with a good failsafe though. Last time my WI went out I fragged a turbo.
Old Feb 13, 2009 | 06:10 AM
  #82
EVO8LTW's Avatar
Originally Posted by JohnBradley
The thing is this was on a road course and I havent ever tuned a car leaner than 11.0 for 20 min lapping sessions with higher timing and low boost with a splash of racegas added to the mix.
When you are talking about 11.0, are you talking about a 3rd gear pull on the dyno or 4th or 5th gear street/track pulls? I've noticed that my AFRs are always much richer on the track pulling down the straights in 5th gear than they ever are on the street or dyno in 3rd gear.
chaotichoax
Apr 12, 2020 11:55 PM
MitsuBeastly
130
Aug 7, 2008 09:30 AM
razorlab
Apr 28, 2007 11:25 PM
EVOVII_SWE
Sep 9, 2004 02:02 PM
