Knock sensor detection via MUT
Old Oct 24, 2008 | 04:54 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Originally Posted by evo828
On 96530006 there is a big subroutine for knock starting at adr 26360 - however I got lost....
Howoever - MUT72 logs FFFF8A0B; but in the dissassembly - some knock dynamics goes into FFFF8A0A - so we need to log 8A0A as well as another MUT. Am I right?
If you want I may send you my disassy.
Mas nejaku postu alebo kde to mam ulozit?
Old Oct 24, 2008 | 06:06 AM
evo828's Avatar
poslal som PM
Old Oct 24, 2008 | 06:22 AM
acamus's Avatar
Originally Posted by acamus
Yes, even knock sum count per one ignition degree (3 in stock) can be edited.
I try to locate the same in some of well known ROMs like 88590015 and get back with locations.
Ok so it goes like this in 88590015:
In sub 2B434
first sub EE50 gets downcounter the resolution is masked with F, this resolution could be changed and less ECU cycles are needed for "decay".
second sub E82C checks if interrupt from timer occured, then these two values "added" and say if the decay time is still there.
To be able to say the location for the timer setting itself I will need more time, and it can affect more locations not only decay. Maybe mrfred can help here as this is his ROM.
Knock_Sum is compared with byte 13A6 - low
Knock_Sum is compared with byte 13A6 - high
these values have effect on Octane_Number subtraction of 1%
(stock 3) value is at word 17DE or word 17E0 depending on some bit array, which I do not know the purpose yet.
taenaive
Nov 1, 2009 08:56 PM
jcsbanks
Sep 19, 2009 01:34 PM
R. Mutt
Aug 5, 2008 10:08 AM
SlowCar
19
Oct 15, 2007 02:34 PM
tlcoll1
18
Jan 5, 2007 01:40 PM
