Please help with NLTS
Old Nov 4, 2008 | 07:17 PM
ant_turbo's Avatar
Ok im using v5 this is how I have it setup!!
1st of my rev limt is @8056,, I have a few questions?? Ok my rpm drop-1000 so does that mean that my RPM drop will drop from 8056 to 7056?? and when should I shift at?? Ok and what does LOAD THRESHOLD mean?? Does it mess with timing or fuel at that LOAD that it is set at
RPM DROP-1000
TPS THRESHOLD -98%
SPEED THRESHOLD -200mph
LOAD THRESHOLD -150
Old Nov 4, 2008 | 07:25 PM
fryedchikin's Avatar
NLTS RPM Drop - When the other conditions are met the ECU will apply a revlimit of 'shift rpm - drop rpm'.
NLTS TPS Threshold - What TPS is required for NLTS to active the revlimit
NLTS Speed Threshold - What is the minimum speed you must be travelling at to enable NLTS - basically allows you to slip the clutch on launch
NLTS Load Threshold - What is the minimum load for NLTS to activate - for the down-shift blippers!
Original post https://www.evolutionm.net/forums/sh...05&postcount=1
Old Nov 4, 2008 | 09:33 PM
tephra's Avatar
yeah your speed threshold is way to high, leave it at 20ish so the NLTS system enables once the car is moving
Old Nov 4, 2008 | 09:37 PM
ant_turbo's Avatar
What about the rest off the settings are they ok where there at???
THANKS
RPM DROP-1000
TPS THRESHOLD -98%
SPEED THRESHOLD -20mph
LOAD THRESHOLD -150
__________________
Old Nov 4, 2008 | 11:50 PM
tephra's Avatar
should be good.
tephra
Apr 22, 2026 11:03 AM
jakgal04
Jul 31, 2016 11:42 PM
jcsbanks
Jun 21, 2013 03:29 PM
jameswwt
10
Dec 22, 2011 12:19 PM
GEARS
Mar 30, 2008 10:52 AM
