Changes in Boost after LICP & FMIC Install??
Old Nov 18, 2008 | 10:11 AM
racer135's Avatar
I installed a Nisei LICP and a Perrin FMIC and now I am seeing a boost overshoot with the ECU Boost Control. Is it common to have to retune the ECU boost after a LICP & FMIC installation? I have not log my car yet to see exactly what it is doing. I was just curious to see if this has happened to anyone else before.
Old Nov 18, 2008 | 10:21 AM
lemmonhead's Avatar
yup I heard like a 2psi difference. less restriction more boost. got to retuen a little.
Old Nov 18, 2008 | 12:05 PM
racer135's Avatar
That's what I am seeing about 2 PSI more.
Old Nov 18, 2008 | 01:50 PM
mplspilot's Avatar
better fmic>less pressure drop>more pressure at manifold. results vary with different fmic cores.
Old Nov 18, 2008 | 07:34 PM
gunhaha's Avatar
I got 2 psi more with just the Nisei LICP.
Old Nov 18, 2008 | 11:55 PM
oldevodude's Avatar
I thought bigger intercoolers actually drop pressure due to being larger in size. a lot of intercooler manufacturers will also provide drop measured. When I installed a Turbo XS intercooler I actually lost about 1psi although I know the intake charge is much cooler and made more power due to cooler intake charge.
You are correct when you say results vary I thought I would share my results.
Old Nov 19, 2008 | 06:26 AM
matt55's Avatar
N/M , miss read .
Really should stop driving and reading Evom at the same time .
Old Nov 19, 2008 | 06:30 AM
GTLocke13's Avatar
All intercoolers have a pressure drop associated with them. Less restrictive intercooler = less pressure drop = higher intake manifold pressure. Generally the bigger an intercooler is the less restrictive it is, but not necessarily.
Sheasta
Dec 16, 2015 12:09 PM
w00ts
Dec 1, 2013 11:15 AM
Topdown
Northwest Region
Dec 7, 2011 04:56 PM
EVIL_EV0
75
Jan 10, 2008 06:13 PM
vmsturbo
Jan 19, 2007 12:06 PM
