Knock control - load vs RPM table found
Old Apr 30, 2009 | 01:17 PM
  #286
elhalisf's Avatar
Originally Posted by tephra
lower your knock retard hold time, so knock drops off quicker
were is that table? i went through the entire thread and could not find it.
Old Apr 30, 2009 | 01:27 PM
  #287
Appauldd's Avatar
I found that I hadf a couple addresses different for LS and BE. I changed them according to that post.
I noticed that if I change the RPM value for the BE Start it will also change the LS start value. This is using the following addresses....
LeanSpool Enable=2500 (address = 1681)
LeanSpoolDisable=7800 (address = 1685)
BoostEnhancement (anti-lag) START RPM= 0 (address = 1680)
BoostEnhancement (anti-lag) STOP RPM= 1500 (address = 1682)
Old Apr 30, 2009 | 01:42 PM
  #288
nonschlont's Avatar
Let me first say, that This is kick A$$! Excellent work jcsbanks!
+1 I went through my rom, and I do NOT have this table. And I have read most of this thread... Can some1 post up the patch, so I can add it to my 88590015?
I will start going through this thread again, to see if I can find it...
Edit: I went through the entire thread, and didnt find any info reguarding this "knock retard hold time" But I now understand things...
TIA
Phil
Old Apr 30, 2009 | 04:27 PM
  #289
tephra's Avatar
ive posted it a couple of times - search for posts by me with "knock" and "time" and then you should find the address.
^ applaud - dont use the BE addresses, you can see that BE start overlaps LS start, and BE stop actually overlaps ANOTHER LS parameter...
Old Apr 30, 2009 | 06:21 PM
  #290
elhalisf's Avatar
have you located the address for the 94170015 rom id?
Old Apr 30, 2009 | 07:31 PM
  #291
nonschlont's Avatar
Dave, this is what Im looking for, right? And is this the correct address for my rom 88590015? And I'll set it to 80. and change the "NewMaps" w/ the knock control stuff...
<table name="KnockSum decay timer" category="NewMaps" address="1384" type="1D" scaling="uint16"/>
Old Apr 30, 2009 | 07:32 PM
  #292
tephra's Avatar
might be right.
whats the original number? 160? if so then you are probably ok to change it...
Old Apr 30, 2009 | 07:42 PM
  #293
nonschlont's Avatar
might be right.
ya the original # is 160. I set it to 80, per your recommendation.
Old Apr 30, 2009 | 07:46 PM
  #294
tephra's Avatar
It's not really a recommendation, just what helped me
160 -> 80 = half the amount of time for knock to come down...
Old Apr 30, 2009 | 07:48 PM
  #295
nonschlont's Avatar
sounds good to me. I'll give it a shot... thanks again.
Old Apr 30, 2009 | 07:52 PM
  #296
phenem's Avatar
Dave, do you know the address for 96530006?
~Zach
Old Apr 30, 2009 | 08:00 PM
  #297
tephra's Avatar
try 0x1784
Old Apr 30, 2009 | 08:13 PM
  #298
Appauldd's Avatar
So am I OK with what I changed it to? Is the settings above "stock" so I can delete them?
Old Apr 30, 2009 | 08:16 PM
  #299
phenem's Avatar
That's it, thanks!
Old Apr 30, 2009 | 08:47 PM
  #300
Appauldd's Avatar
try 0x1784
This works for 94170015 too.
