Knock control - load vs RPM table found
Old Jun 4, 2009 | 04:28 PM
  #316
Stealth Ag's Avatar
Problem solved
Old Jun 4, 2009 | 06:27 PM
  #317
Appauldd's Avatar
Did you add the definitions to your Evo7Base too???
Old Jun 5, 2009 | 10:37 AM
  #318
Stealth Ag's Avatar
sorry to clutter...solved the issue...it was with my comp not the code
Old Jun 22, 2009 | 07:18 PM
  #319
rodrig.diaz3's Avatar
Any one have it for 88580013??
regards
Old Jul 18, 2009 | 04:20 PM
  #320
mutex12's Avatar
evo 8 gsr 93660005 knock load addresses
Does anyone have the Knock Load addresses for a jdm e8 gsr 93660005 rom?
<table name="Knock Load" category="Knock Control" address="????" type="2D" level="2" scaling="Load8">
<table name="X" address="????" type="X Axis" elements="10" scaling="RPM"/>
</table>
I've had my car on a dyno with head phones, and we kept pulling timing to reduce knock b/w 2500-3500 rpm, but this had little effect - so we concluded it's probably phantom knock - twin plate clutch/exhaust/or just engine higher rpm is fine.
It looks like the remaining 96530006 definitions can be used, as they produce the expected default 13, 18, 20, 2, 7 values.
<table name="Knock Multiplier - Low RPM" category="Knock Control" address="177a" type="1D" level="1" scaling="uint16"/>
<table name="Knock Multiplier - Mid RPM" category="Knock Control" address="24aa" type="1D" level="1" scaling="uint16"/>
<table name="Knock Multiplier - High RPM" category="Knock Control" address="21de" type="1D" level="1" scaling="uint16"/>
<table name="Knock Adder - Single Gain" category="Knock Control" address="1780" type="1D" level="1" scaling="uint16"/>
<table name="Knock Adder - Triple Gain" category="Knock Control" address="177c" type="1D" level="1" scaling="uint16"/>
Thanks.
Old Jul 18, 2009 | 04:55 PM
  #321
wreckleford's Avatar
</table>
Thanks.
Knock load is at 3e7e and rpm is at 5b66.
Old Jul 18, 2009 | 10:47 PM
  #322
mutex12's Avatar
Perfect, thanks for your help
Old Jul 20, 2009 | 08:29 AM
  #323
Rob_GPT's Avatar
Read it all, used it, car is running GREAT!
Old Jul 21, 2009 | 02:58 PM
  #324
borjaland's Avatar
This should be good for 96420011:
<table name="Knock Load" category="Knock Control" address="421a" type="2D" level="2" scaling="Load8">
<table name="X" address="6542" type="X Axis" elements="10" scaling="RPM"/>
</table>
P.D. Mr. jcsbanks AMAZING JOB thanks!!!!!!!
Old Jul 21, 2009 | 03:14 PM
  #325
borjaland's Avatar
Originally Posted by whitey4d
Ok so my original rom is 96420008. Ive got all the knock tables up and running. the only problem Im having as the scaling of RPM on the knock vs load threshold table is off. Everything else is good.
Does anybody know the correct addresse for RPM scaling in the table in 96420008?
Thanks alot.
Try this
<table name="X" address="6532" type="X Axis" elements="10" scaling="RPM"/>
Old Jan 1, 2010 | 11:27 PM
  #326
amak87's Avatar
I've had phantom knock for a while due to a loud lifter tick.. could someone please post up the rom edit for Evo 9 0015. And help me out by giving me some basic changes that would help eliminate my phantom knock..
Old Apr 2, 2010 | 09:55 PM
  #327
philr8's Avatar
any 1 have the knock load tables for 9626009, i am getting knock counts around 3-3.5k rpm at 80 -120 load, i have listened with detcans and it is false,
Tried removing timing and it hasnt helped
thanks
Phil
Old Aug 21, 2010 | 11:01 PM
  #328
Beriant's Avatar
Hello everyone, I am experiencing this same problem with my 2000 eclipse.
I was wondering if anyone already had the information to get these knock control tables for my rom. The internal ID is 2181002 and this ecu has the 203 processor which I believe the same as the evo 5/6
Old Aug 23, 2010 | 06:31 AM
  #329
benpgreen's Avatar
You should just use the 96530706 Tephra V7 rom. I use it on my 2000 eclipse turbo and have successfully tuned out the knock problems by changing the knock multipliers.
Old Aug 23, 2010 | 10:28 AM
  #330
Beriant's Avatar
that will not work, I can copy the xml data into my xml and the tables will pop up on my rom in ecuflash but the address is wrong. It just shows me a blank white box.
