Air Temp Compensation table
Old Jul 14, 2010, 09:44 PM
  #256
D-VO's Avatar
Originally Posted by PlanoEvo
Bump anyone?
Which ROM are you using for V5? It should be under the fuel section called "Airflow/Hz Baro and Air Temp Compensation".
Old Jul 24, 2010, 10:51 AM
  #257
VGergo's Avatar
when the temperature is hot the ecu is reduceing the timing advance and richen up the fuel with multiplier value in the fuel-timing trim vs air temp table ?
Old Sep 6, 2011, 11:06 AM
  #258
rawkus's Avatar
Does anyone have these tables defined for 90550001? Thanks!
Dan
Old Apr 10, 2014, 07:39 PM
  #259
tsitalon1's Avatar
Maybe I'm looking in the wrong place - but I'm having an issue with Open Loop cruise AFR's drifting a from 15.3 to 17 over time.
Is this table still valid in V7, or is it named something else...maybe "air density compensation for load and ipw"??
I cannot adjust the "air density compensation for load and ipw" table in V7 as any changes revert the cell to "0000"
Am I looking in the wrong place?
Old Apr 13, 2014, 01:25 AM
  #260
merlin.oz's Avatar
for 90550001:
<scaling name="CF128" units="Correction Factor" toexpr="x/128" frexpr="x*128" format="%.3f" min="0" max="2" inc="0.0078125" storagetype="uint8" endian="big"/>
<scaling name="TEMP" units="*C" toexpr="x-40" frexpr="x+40" format="%.0f" min="-40" max="115" inc="1" storagetype="uint16" endian="big"/>
<table name="Intake Air Temp Fuel Correction" address="38DC" category="Closed-Loop Control" type="2D" scaling="CF128">
<table name="Intake Air Temp" address="5194" type="Y Axis" elements="8" scaling="TEMP"/></table>
Old Apr 25, 2014, 05:53 PM
  #261
tsitalon1's Avatar
Would anyone have one for 88590715?
Old Apr 26, 2014, 02:01 AM
  #262
merlin.oz's Avatar
for 88590015
<table name="Intake Air Temp Fuel Correction" address="30FE" category="Closed-Loop Control" type="2D" scaling="CF128">
<table name="Intake Air Temp" address="714A" type="Y Axis" elements="8" scaling="TEMP"/>
</table>
Old Apr 26, 2014, 06:12 AM
  #263
tsitalon1's Avatar
Originally Posted by merlin.oz
for 88590015
</table>
Thank you!!
Old Apr 26, 2014, 07:12 AM
  #264
tsitalon1's Avatar
for 88590015
</table>
Would this table help cruising AFR's in Open Loop mode?
I have open loop cruising enabled and I'm seeing 0.7 - 1.0 shifts in cruising AFR's after cruising for awhile some time, car starts at 14.9, but ends up at 16.1 by the end of my normal day.
Old Apr 26, 2014, 11:59 AM
  #265
merlin.oz's Avatar
I include it in the Closed-Loop Control group, but it is also valid for open loop operation.
Old Apr 29, 2014, 03:52 PM
  #266
tsitalon1's Avatar
Thank you!
Think it could resolve my problem above?
Old Nov 20, 2014, 08:44 AM
  #267
misterchonger's Avatar
I am having similar issues as you are with the "air density compensation for load and ipw" table. I can edit the scale to allow me to edit the table but it seems this table should be left alone from all that I've read. Not sure of which table is the best to edit to help me address my root problem, which is that I'm leaning out when the temp drops.
Old Nov 20, 2014, 07:26 PM
  #268
ReaperX's Avatar
^ I am assuming your leaning out during WOT? If so what's your method of boost control?
Old Nov 20, 2014, 09:35 PM
  #269
Yessir. I'm using manual boost controller. On tephra 7 maf.
Old Nov 21, 2014, 02:34 PM
  #270
ReaperX's Avatar
With the colder weather have you turned down the boost controller any? You could possibly be higher loads in the upper rpm range that you were not before and your fuel table may not be setup to anticipate this. Turn your mbc down a touch and you'll more than likely see your afr's fall back in line.
I tuned my car to run load based boost control, and to run the same load curve in the winter that I do during the summer it equates to 1.5 to 2.5 psi less during the winter where I live (depending on temperature).
Quick Reply: Air Temp Compensation table
