DLL help
Old Dec 6, 2008 | 12:22 PM
Shacochis06's Avatar
yea thats what DLL has it for the 03-05 but i need it for a 06
Old Dec 6, 2008 | 12:23 PM
Does everything in the graph contents to the left look right Creamo?
Old Dec 6, 2008 | 12:24 PM
Creamo3's Avatar
Originally Posted by Shacochis06
creamo i really dont think u wanna see yours lol its at like 200 something
i know im probably missing something really lil thats throwing the numbers off complety
Haha, yeah my car is pretty weak
Your ratios should look like this for the IX:
Gear Ratios
EVO & EVO RS EVO MR
1st: 2.785:1 1st: 2.909:1
2nd: 1.950:1 2nd: 1.944:1
3rd: 1.444:1 3rd: 1.434:1
4th: 1.096:1 4th: 1.100:1
5th: 0.761:1 5th: 0.868:1
Final drive: 4.529:1 6th: 0.693:1
Old Dec 6, 2008 | 12:26 PM
i put those into the new car definition still didnt do anything to the hp/trq numbers
Old Dec 6, 2008 | 12:47 PM
EvoJoeIX's Avatar
change your smoothing factor
Old Dec 6, 2008 | 12:49 PM
EvoJoeIX's Avatar
eh maybe not... even with my smoothing at 5 im making 318/356 on DLL
Old Dec 7, 2008 | 09:27 AM
nobody know whats wrong?
Old Dec 7, 2008 | 11:33 AM
PVD04's Avatar
If you post one of your logs I'll run it through and see what I get. Without a screen shot of the car definition it's hard to help. You either have a problem with gear ratios, vehicle weight, tire size, or you're analyzing a 4th gear log with 3rd gear settings.
-Paul
Old Dec 7, 2008 | 05:58 PM
Mellon Racing's Avatar
attach a zip file with a log in it of a 3rd gear pull on flat ground and we need to know if it's a VIII or IX and 5 or 6 speed, custom wheel/tire size and weight changes etc...
Old Dec 12, 2008 | 05:35 AM
Creamo3's Avatar
Did you ever get the issue resolved? I would be interested to hear what the problem was.
Old Dec 12, 2008 | 06:05 AM
sk8terdude929's Avatar
Can you post a log, i am having similar issues and i would like to see if i am doing everything correctly. Does anyone know if there are any instructions on using the DLL? Are there specific items that need to be logged?like(Rpm,speed,A/F ratio)? Thanks
Old Dec 12, 2008 | 06:51 AM
Mr. Evo IX's Avatar
Originally Posted by EvoJoeIX
DLL is very inaccurate.. i wouldnt even waste your time
on DLL my car is 490hp and over 500ft lbs of torque. plus its just so easy to manipulate your numbers by changing factors. like weight in car, gear ratios, ect.
i used it once and havent used it since.
I disagree with your entire statement. It sounds like your blaming the tool for operator error. DLL is an inertia type dyno that uses the info you put in it (weight, tire size, gear ratios) along with the car's existing sensors. If you got unreasonable numbers then it was your fault, not the program's fault. Also your have to drive the car in a repeatable fashion on a flat surface to get repeatable results.
Any dyno can be manipulated, and many of them are for various reasons (normally to compare with someone elses dyno down the street).
Is it as accurate as a Mustang chassis dyno? No, but it only costs $39.95 - what were you expecting?
Old Dec 12, 2008 | 06:58 AM
Mr. Evo IX's Avatar
Also the 6 speed cars final drive is 4.583 vs the 5 speed 4.529
http://www.google.com/books?id=8ZkuD...lioVcR_oyRYQU0
http://www.supercars.net/cars/3527.html
http://www.topspeed.com/cars/mitsubi...y-ar10511.html
Gear Ratios Evo VIII
1: 2.928:1
2: 1.950:1
3: 1.407:1
4: 1.031:1
5: 0.720:1
Gear Ratios Evo IX
1: 2.785:1
2: 1.950:1
3: 1.444:1
4: 1.096:1
5: 0.761:1
Gear Ratios MR
1: 2.909:1
2: 1.944:1
3: 1.434:1
4: 1.100:1
5: 0.868:1
6: 0.693:1
Final Drive: 4.583:1
Old Dec 12, 2008 | 07:38 AM
some people think evoscan and DLL are the same thing...DLL is accurate, evoscan is all over the place and inconsistent. Maybe it's better in the newest version, I haven't tried it yet.
Old Dec 12, 2008 | 01:30 PM
Sorry if this is a newb question but, i have been logging with "evoscan" for a little while now and had though the "DLL" was part of that software, but as someone stated above it is not part of evoscan. Where would i find the "DLL" software? Thanks in advance
